Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
How do you replace the brushes on a hoover f7452-900
  • 377 Answers
You have two model numbers showing. I could not find anything on the F7425-900, but I did find an exploded view of the F7452-900 If you go to this URL:
http://www.ereplacementparts.com/hoover-f7452900-steamvac-all-terrain-parts-c-37315_37419_37439.html
you can see the exploded view. This itself does not provide directions on changing the brush, but it does indicate that by removing a few screws on the brush and squeezing some plastic tabs (looks like any way) that you can pull the brush off. If you have the new brush already, it may indicate some of the connection points.
Hope this helps a bit. Paul
Posted on Oct 05, 2010
Why don't the brushes go round on my Hoover carpet cleaner
HI There,
Here's a link to a Fixya repair solution that I recently did on this exact problem. It's actually a fairly common problem. The second link is to another solution that will walk you through step by step how to replace the turbine assembly if you find out this is what the problem is.
How to Diagnosis a Hoover steamvac spinscrub brushes stop spinning:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
How to replace the Brush Turbine Gear if you find out this is what has gone bad:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
If you need to purchase a new spinscrub brush block, here's a direct link to the exact brush block that's used in your model:
Hoover SteamVac Brush Block - 5 Brushes Part # 48437022
If you have any follow up questions, please don't hesitate to ask them by using the comment form here on the Fixya repair page.
Thank you,
Chris Jones
GoVacuum.com
May 12, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
New Hoover Steam Vac's brushes do not spin
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Turbine Brush Gear Part # 43191008
F5914 Parts Link
http://www.usavacuum.com/Hoover-F5903-F5904-F5905-F5910-F5912-F5914-F5915-s/138.htm
Feb 28, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes donot turn when asked to shampoo
Hoover SteamVac Replacement Turbine Brush Gear Part # 91001097
F7425 Parts Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
Feb 09, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes do not turn
F7425 Parts Link
Dec 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
How to clean my Hoover steamvac brushes? or
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
220 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
