Question about McCulloch Garden
My chainsaw is reving too high - I found the screw that adjusts it but not sure which way to turn it - when I did turn it it either revs its guts out or doesn't start - so now afraid to turn it too far one way or the other for fear of blowing it up - so do i turn it clockwise or anti clockwise to slow it down???
  • 7,733 Answers
  • Start the engine and let it run long enough to warm it up (usually 1-2 minutes is sufficient). Shut off the engine.
  • Check the air filter to see if it is clean, and if it is not, replace it. Check the spark arrest filter in the muffler to be sure it is clean; clean the spark arrester if it is dirty by removing it and burning the deposits off with a BernzOmatic torch, or other torch. Replace the filter if it is in really bad shape.
  • Turn the "H" screw counterclockwise until it stops (should be no more than a 3/4 turn with a small flathead screwdriver. Turn the "L" screw clockwise until it stops. Then turn it counterclockwise 1/4 turn.
  • Set the Idle Speed
  • Be sure the carburetor is set to the standard setting. Start the engine.
  • Turn the "LA" screw clockwise until it stops, or until the chain begins to run. Turn the screw counterclockwise 1 x 1/2 turns.
  • Call your local chainsaw repair shop to have them repair the chainsaw if the chain continues to run after completing Step 2.
  • Choppy Idling and Acceleration Adjustment
  • Verify that the low speed screw "L" is 1/4 turn open.
  • 3 Turn the low speed screw counterclockwise until the engine idles and accelerates.
  • Verify that the new setting works after the engine has cooled and warms up again.
  • Posted on Oct 05, 2010
    What are the air and gas settings for a poulan micro XXV chain saw
    adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
    Aug 12, 2014 | Garden
    Correct adjustment
    there are two adjusting screws on the crab one with a H and one L tightening the H one untill it stops then turn back one and a quarter turns start the engine rev the engine and adjust the screw from there ..
    Mar 30, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
    Poulan chainsaw, I rebuilt the carb with all new everything. Now it will start with choke all the way out. Idles really high. If I push choke in, it dies instantly. The hi-lo and Idle is off I know for...
    get it running on idle,adjust the idle down till it runs hairy,then adjust low speed mixture screw till you get it highest revs,then keep repeating that till you get it idling normal.rev saw up max revs,adjust high speed jet, in or out till you get max revs,then screw out one quater of a turn.That lets enough fuel thru to cool the sparkplug tip..If thats no good,redo the carbi.Check the tiny filter under the needlevalve hole.Check the needlevalve diaphragm height.recheck gaskets are right way round
    Nov 03, 2013 | Husqvarna Chain Saw 20" Bar
    Engine dies upon acceleration after starting and idling
    turn the high speed and low speed mixture screws right in[gently]then out 2.5 turns.start it up,screw the idle screw up till it will idle,then adjust low speed mixture screw in or out so you get the highest idle.keep lowering the idle so as you adjust the screw,it wont get it any higher in revs.so by now it should idle.next,open the throttle wide,and adjust the high speed screw until you get maximum revs..then,turn screw 1/4 turn out.that makes it slightly richer,cooling the plug with droplets of petrol.you dont want it lean.if it wont rev fully,check the fuel filter.they get dirty quite often
    Jul 02, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
    How do you adjust high, low, and throttle on echo 3400 chainsaw
    Ok, this is an easy job, and a quick tune up. First start up your saw, rev it some so it warms up. Next, make sure your saw idles, if not just turn up the idle a bit first before this. With your saw idling on the ground, turn the L screw about 1 turn either side of where it is, and listen to obtain the fastest and smoothest idle, that takes care of the L screw. Now the H screw must be adjusted while the the saw is at full throttle, turn the H screw and listen for maximum and smoothest engine speed. I sugest this be done with the chain and bar removed from the saw. After you adjust the L and H, then adjust idle to suit.
    Jun 16, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
    Carb rpl and adjustment
    you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
    Apr 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
    What aere the primary settings on the high & low speed screws on a sears 42cc chain saw engine?
    start off with the low speed screw turn it right in then undo it 1+1/2 a turn start saw up and screw slow running screw in or out a little bit at a time till the saw ticks over,,then give the saw full throtel and screw the fast screw in or out till the saw is reving as fast as it will rev at
    Mar 25, 2010 | Garden
    Cannot adjust carburator on husqvarna chainsaw 435
    the screws are on the side of the carb very small heads flat screw driver is needed as they have a cover on them it has to fit inside the cover H (high) and L (low) tighten them all the way in tight but not forcing them turn anti clockwize 1 1/4 turns try to start the saw pull the trigger and adjust the H (high) till it runs smooth then  let it idle then pull the trigger again saw should rev without loss of revs if it does turn the L (low) small amount either way till it does  hope this helps
    Oct 19, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
    How do you yune a muculloch mac 110 chainsaw
    There should be a small screw near carburetor Labeled L and one H. Set the L or low jet first by screwing it in slowly until the engine drops RPM then start screwing it back out until it quits gaining rpms then screw it back in one half turn. Be careful on the high jet as it requires you to hold the throttle wide open. Do the same proceedure as low. Screw it in till drop them out till the RPM is maxed out then back in a half a turn. Try reving the engine several times and it shouldn't hesitate. If it does, open the H valve a small amount. Go back to idle after adjusting H valve and make sure the engine still idles smoothly or you'll need to re-adjust it again. After it's running well then adjust idle speed. Should be set a little fast but not enough that the chain turns while idling.
    May 21, 2009 | McCulloch Garden
    Husky 350 chainsaw idle to high
    First there is an throttle idle screw that adjust the amount of throttle at idle try turning it ccw until it idles down. If this adj is at its lowest level then adjust the L screw until you get the idle you want. Then try to rev up it should rev up without hesitation if not hold down on throttle untill you get max rpm it it tries to cut out etc. at high rpm adj. the H screw until you get max rpm. then adj your L screw again for proper idle. You may need to do this back and forth for awhile until you get max. performance.
    Apr 10, 2009 | Husqvarna Garden
    Garden Logo
    307 people viewed this question
    Top McCulloch Garden Experts
    Jim Parker
    Jim Parker
    roeb
    Are you a McCulloch Garden Expert? Answer questions, earn points and help others
