Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
I am using Canon 1000D dslr for more than 18months, it was working fine until last Sunday. I went outside and started taking few shots... it was not focusing properly (or should I say not at all!) and pictures are coming blurred. When I press the shutter button half, it should run the motor (in autofocus mode) and focus, but it is not doing anything (i.e. no red dots are coming)... what could be the problem? Thanks for any help.................
The autofocus motor could be be broken, or the lens may not be communicating correctly with the camera. One thing that can help if it's not communicating correctly is to clean the lens contacts. If you take the lens off, you should see some gold plating on the plastic on the side of the lens that attaches to the camera. You can clean it by lighting rubbing it with a new, CLEAN pencil eraser. if that doesn't work, you may need a new lens unfortunately. best of luck!
Posted on Mar 14, 2011
Canon EOS 1000D. Busy signal. No response from any functions. Cannot take pictures.
This is a long shot but you can try to remove the battery for a few minutes and that should "reset" your camera. Put the battery back in and see if it works, if not you can try calling Canon service at 1-800-652-2666 and they may be able to help you.
Good Luck!
Jul 03, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
I have a canon eos 1000d and as i was shooting i turned on the noise reduction on and i think i manage to take another 3-4 shots after that.Then i realized for some reason the lens was properly focusing...
Good Luck!
Jun 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
What does error 9 mean in a Canon 1000D DSLR camera ?
shooting is not possible turn the power switch to (off) and (on) again por re- install the battery.
Jan 23, 2011 | Canon Rebel XS / Eos 1000D Digital Camera...
Hi, i have recently bought a used canon 1000d. it worked fine at first after about 500 shots, it cant work in AF mode please advise thanks
Do you have the switch on the lens set to AF and also you have to go into the settings and set the focus to AF it might have accidentally got switched to MF on the lens or in the camera settings. if they both aren't set to AF then it wont work Hope this helps
Aug 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Will this Lens fit the Canon DSLR 1000D
Yes, it will fit Canon 1000D.
But I'll recommend you to try lens in a shop before buying - picture quality can be low.
Jun 24, 2010 | Rokinon 6502600 mm f816 for Canon
Err 99 followed by the "Busy" issue in the viewfinder
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Jul 26, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon 1000D wont let me shoot
It can be the cold or wet. try to keep it in dry place and change the battery.
Feb 04, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon eos 400d
Contact Canon - some makes of lens which are not Canon are not electronically compatible for various reasons, and can actually damage the camera. So, get using the phone and check if it is compatible before doing anything else - but personally, I would not use the lens until I find out
Jul 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
I have a Canon Powershot SD550 Digital Elph IXUS 750 and last sunday I shot some photos outdoor at the equestrin center, but when I went indoors I found I didn't have a flash operating either on automatic...
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2008/05/simple-fixes-for-cameras-that-wont-take.html
May 27, 2008 | Canon Cameras
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
157 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
