Question about Tappan TMT104E1 Microwave Oven
I have a tappen Tmv151fs unit . My unit shuts off after 1 or 2 seconds reguardless of what time is put in. the display goes to 00:00 then after 5-10 sec goes to : 0 then I can try again. after 4 or 5 times sometimes it will work. Also at times it appears the pad loses memory so the add 30 sec key becomes the 6 key and the 9 becomes the start. I cut the power and it resets after a few seconds? Thanks
2 Suggested Answers
  • 4088 Answers
SOURCE: Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Posted on Aug 19, 2009
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Sometimes oven does not work. when ya hit start it just clicks - the screen looks normal for about 2seconds & then shows the clock time.
Sounds like is what's happening:
Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back.
That would be a bad upper interlock switch and charred connector. If so, see:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Dec 11, 2012 | Panasonic NNSN797S Microwave Oven
I have a Panasonic microwave convection that runs for 2 or 3 seconds, then cuts off. It doesn't matter what setting or length of time you program into it, it will run a couple of seconds and shut down. Is...
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Sep 08, 2010 | Panasonic NN-C994S Convection/Microwave...
Micro wave starts and runs for 2 seconds then shuts down
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
Aug 22, 2010 | Panasonic NN-H275 Microwave Oven
Panasonic NN-S254BF microwave oven runs for 2-3 seconds and then shuts off'
May 31, 2010 | Panasonic NN-S254BF Microwave Oven
Starts then shuts off after 2 seconds
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Sep 18, 2009 | Panasonic Microwave Ovens
Panasonic Genius Sensor 1300W
Aug 30, 2009 | Panasonic NN-SN657SMicrowave Oven
Turns itself off after only running 2-3 seconds
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
If yours is not a Panasonic, Please reply back with your brand and model number so we can help you.
Aug 08, 2009 | Panasonic NN-SN657SMicrowave Oven
Runs for a few seconds then shuts down. Sometimes will work ok then next time shuts off in a few seconds.???????
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 7 seconds, it has a problem with the inverter.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Jul 09, 2009 | Panasonic Microwave Ovens
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
75 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
jdtech
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
