Question about KitchenAid KGST300 Gas Kitchen Range
Ran the self clean mode and even after cooling for about 12 hours the door locked light stays on. The display shows code F5 E7 and the message "door locked". I hit cancel to reset, unplugged the unit and plugged it back, and still no change. There is a clicking sound that sounds like it is coming from the display every 10 seconds or so. The to range works fine. Is this something a homeowner can repair?
aborcass
  • 2651 Answers
SOURCE: Amana gas range
the only f5 code listed for the amana range states faulty erc(electronic range control) solution replace control
Posted on Feb 26, 2008
FreeTech
  • 426 Answers
SOURCE: oven door locked
unplug the oven for a few hrs, need a brand and/or model number to look up diag. codes
Posted on Jun 13, 2008
SOURCE: KGRA806PSS00
http://www.fixya.com/support/p106259-kitchenaid_kgra806pss_gas_kitchen_range
Posted on Jun 29, 2008
  • 8 Answers
SOURCE: Door will not unlock after self clean.
It's probably the timer motor which is stuck. unplug the range!! I recently had the same problem with my whirlpool (hereinafter known as **** inc.) range. Self cleaned the oven and then the door wouldn't open. Googled up similar problems and generally found out that ****inc. had this problem on both gas and electric ranges and it costs an arm and a leg for a new board plus labor. Found out how to manually open door with coat hanger but of course still had problem with same error messages; also the oven, clock, etc wouldn't function. Took the cover off the back of the stove. UNPLUG THE STOVE On the left rear facing the back of the range he found the timer motor had stopped.He unplugged input(230 volt power) leading to the stove, then unplugged and insulated the wiring to the timer motor and the microswitch on top of it ( 4 wires). Then he took the long steel wire off of it and unlatched the oven door. Told me that this probably had something to do with the timer motor on the self cleaning cycle and that it was stuck Said this whole thing could probably be fixed with a bit of WD40. Said probably nothing wrong with board but it sure must be a moneymaker for **** inc. The service techs probably clean the timer motor, say they changed the $300 board, and go on their way. Plugged stove back up and voila! Everything worked except self cleaning function. Hope this helps someone. caution!!!! Do NOT use the self cleaning function unless you fix the timer motor. Replace it or clean it.
Posted on Nov 28, 2008
mastersaintx
  • 928 Answers
SOURCE: I have a KGST300 gas
As most electronic devices go you can just unplug it first for about a few mins then plug it back in.
Posted on Dec 02, 2008
My oven is locked. Display shows F5:E7 How do I unlock it?
Vera, Code F5 E7 your latch assembly has failed. Turn oven breaker off to the unit for 5 min. to see if it will reset. If not, then try to set the self clean, wait 1 min. and cancel it to see if that will reset the door latch. If it does not reset the door lock, then you will have to manually open the door and replace the door latch assembly. It's not easy task to unlock the door. You'll need to use a coat hanger and pull the latch assembly from (right - left) by slipping it down between the door and the oven top. Force the latch over to the left and open the door, then you will have access to remove latch.
press the helpful button and follow me on fixya for more tips and info
Appliance411 FAQ After self clean range oven door won open
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0ahUKEwj-qYvv3ffKAhVHKh4KHdaUBgAQtwIIKTAD&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D320yZMp34oA&usg=AFQjCNE0dH2xRKfdY8alz0y7MdjMT86ULA
http://products.geappliances.com/appliance/gea-support-search-content?contentId=16246
How to Troubleshoot the Door Lock on your Stove Range
Feb 14, 2016 | Kitchen Ranges
Self cleaning oven
Pheo,
Turn Breaker/Fuse for the stove, your electrical panel, “OFF” and then “ON”, wait 20 - 30 seconds and the door should unlock.
It may be that the temp sensor is going out and you'll need to have that looked at soon.
Bill
Nov 21, 2007 | Whirlpool GBD307PDS Electric Double Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Oven door locked - display shows F5:E7
Hello there and thank you for choosing fixya
These codes normally show up during the cleaning cycle this is due to the extreem heat used during the self clean operation
Now to fix this is not too hard providing the sensor for the temperature has not been damaged due to the heat
Unplug the oven and leave it sit for 1 hour and do not touch there is a internal reset feature on these ovens that take 1 hour to reset once the hour is up plug in the oven and you may hear a audiable click sound or a buzz sound if so great then all you have to do is to press the cancel or off button then after 5 min attempt to unlock the door
if it does unlock and one of these error codes are still showing this means the the controle panel has suffered some damage and needs to be replace
I have seen brand new ovens have the controle panel fail after the first self clean operation because the parts inside of it fail due to the extreem heat ok?
Hope this helps
Best regards Michael
Apr 20, 2011 | Ovens
Error code F5:E7 Can not get the oven door unlocked or reset this code. What do we do?
Beginner on forumn, don't have any manual in front of me on f5:e7. Sounds like a conventional oven problem, oven door locking. If in fact is some form of conventional heat oven (convection?), I had similar problem with a GE range, it flashed some kind of code seams like which I later interpreted by using owner's manual that explained codes. In my case it was in "cleaning mode" and you can't turn that off unless you unplug or turn breaker off, that puts it back to default mode with nothing running. I simply tried out the self cleaning feature, from there the oven went to full on heat and oven door locked unexpectedly. I learned stays locked till cycle finishes and oven cools, which is some time after the oven automatically switches off, said that it can be a couple of hours before you hear a...click, and now door opens (note to self, don't ever do that again).
Jan 13, 2011 | KitchenAid Microwave Ovens
I have a KGST300 gas freestanding range. I tried to run self clean, but immediately after starting I canceled, as I forgot to remove the oven racks. The process stopped, and the door unlatched, but I...
The manual for your range suggests you call 1-800-422-1230 for error assistance.
sorry i couldn't be of more assistance but this should get you on the right direction
Dec 01, 2008 | KitchenAid KGST300 Gas Kitchen Range
By the way the door lock error will stay there until the oven cools. Once it has cooled it will go away. the reason is in a self clean the oven is supposed to get very hot to clean. The door lock is for your protection. once it has cooled down enough the door lock will go away.
Dec 01, 2008 | KitchenAid Kitchen Ranges
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Feb 10, 2008 | Kitchen Ranges
KitchenAid KGST300 Gas Kitchen Range Logo
35 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
