Question about Sony VAIO VGN-N250E/B Notebook
Where can I get Drivers for a Sony Vaio VGN N250E/B ???
  • Sony Master
  • 7,733 Answers
Here --->link.
Posted on Oct 05, 2010
4 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: sony vaio vgn-n250e laptop microphone problem
You can download what ever Vista driver required for your VGN-N250E Sony Vaio at Sony Vaio Support.
Good Luck.
Posted on Oct 24, 2008
Geekman
  • 32281 Answers
SOURCE: Win Xp Drivers for sony vaio vgn-fw230j
Go to download the drivers that you require from the Sony WEB site, to their support/download page. Make sure you input your model laptop and select the Windows OS that matches your installed operating system.
Use this link :-
http://esupport.sony.com/perl/select-system.pl?DIRECTOR=DRIVER&SR=nav:service_support:electronics:drivers_software:esup&ref=http%3A//www.sony.com/index.php
Posted on Apr 15, 2009
joecoolvette
  • 5660 Answers
SOURCE: Where is HD on VGN-N250E
It's in the bottom left hand corner, as you view the laptop in it's normal position.
Sony Vaio's are not like other laptops in -> this respect.
With MOST other newer laptop's, you burn to disk your personal documents.
(Anything in your My Documents folder. My Pictures, My Music, My Videos, and personal documents you have created)
Then you buy an inexpensive external enclosure, (2.5" for laptops. And Sata for a laptop like yours), insert the new harddrive, and attach the external enclosure to your laptop, via a USB cable.
Then there is a certain key, or keys, you press on the keypad, and a menu comes up for transferring your Operating System, and programs you have installed, onto the new harddrive.
You remove the AC adapter, (Charger) and the battery.
The new harddrive is then inserted in place of the old one. Access to the harddrive, is usually removing a screw or two, then pulling the harddrive out, with part of the laptop body. Reinstall the battery, and plug the AC adapter back in. Away you go.
With the Sony Vaio series, this is not happening.
You have to use an external enclosure, and a 'mirror' imaging program, like Norton Ghost, Acronis True Image, or DriveImage XML, (Free), and mirror image the operating system, and programs to the new harddrive. (Via the external enclosure)
Then the fun(?) begins.
All electrical sources are removed. The laptop is turned over on it's top cover. Six screws are removed around the outside case edge.
One screw is removed towards the Front, and right next to the Memory Compartment Cover.
The laptop is turned back over, and a small flat tip screwdriver is inserted into slots, in front of the keypad. (Jewelers screwdriver)
The keypad is released and tilted back.
A flat ribbon cable is disconnected, from the motherboard that leads to the keypad. The keypad is removed.
Then, a small White flat ribbon cable is disconnected, in front of the keypad area. This ribbon cable connects the Front panel buttons, to the motherboard.
Now, the Top Cover is popped loose from the Bottom Cover. There is a thin parting line where the two halves meet, and a jewelers flat tip screwdriver, is inserted in this parting line towards the back. (Near the LCD screen) The Top Cover is eased up a bit, on one side, then the other side is eased up a bit. Work towards the front.
When getting to the end, (Front), the Top Cover comes off.
Now the harddrive can be seen. There are Two screws towards the Left side, in the corners. These are removed. There is One
screw towards the Right/Front corner. This is removed. The harddrive has a fabric pull 'tab' on the end of it. This is pulled on and the back end of the hardrive is gently lifted up, as it's pulled back. (Left side of harddrive is the back end)
-> Extreme caution is taken here, as there are tiny metal pins on the front off the harddrive, that can easily be bent!
There is a metal thin frame that goes around the harddrive. This is removed, by removing Two screws on each side. The metal frame goes on the new harddrive.
Posted on Apr 18, 2009
I have recently installed Windows 7 on my VGN-N250E. It does not recognize my sd-card. Does anyone know where i can find sd-card driver for win7 for sony vaio VGN-N250e?
I checked the information and found that the computer does not qualify for a Windows 7 Upgrade from Sony. But as we have tried, Windows Vista drivers work with Windows 7 as the core for both the OS is same. I suggest that you download install Memory Card driver for Windows Vista from the below link to resolve the issue with the SD Card. I have also provided the link to download Sony Shared Library which you should install first.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN250EB&upd_id=2383&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN250EB&upd_id=2416&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN250EB&upd_id=2391&os_id=28
Thanks!!!!
Dec 25, 2010 | Sony VAIO VGN-N250E/B Notebook
My sony vaio drivers for WINDOWS7 are not available on net what should I do
hi friend,
If you are unable to download driver for windows 7 no prob just download the driver for windows vista and install it in windows 7 iam sure it will work. click on download to download the driver
download
May 11, 2010 | Sony VAIO VGN-N250E/B Notebook
FROM WHERE CAN I GET WIN.7 DRIVERS FOR SONY VAIO VGN-N250E
As if now windows 7 drivers are not available but you dont have to worry because Basic system functionality should be automatically enabled with the drivers included within the Windows 7 operating system.
However, if one of the drivers that came with the operating system does not work with your system, you can try installing the Windows Vista version of the driver provided by Sony for your model. Many of the Windows Vista drivers are compatible with Windows 7 based on current testing. Make sure you choose the bit version (32-bit or 64-bit) that matches your version of Windows 7.
For for driver download visit this website :
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNN250E
For information about windows 7 upgrade visit this website :
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=24
Mar 23, 2010 | Sony VAIO VGN-N250E/B Notebook
MY SONY VAIO DRIVERS FOR WINDOWS7 ARE NOT AVAILABLE ON NET WHAT SHOULD I DO
Use XP drivers and run them in compatibility mode.
OR
Let Windows 7 find the closest driver.
OR
Use Vista drivers.
Mar 19, 2010 | Sony VAIO VGN-N250E/B Notebook
I have a vaio laptop which on its screen has been written VGN-N250E and on the back of laptop computer model is PCG-7X1L. It seems that my laptop model is VGN-N250E. I couldn't install matlab 2006a on...
"Windows 7 will come to the table, from the get-go, with support for all Vista-certified drivers. Compatibility with devices designed for Vista ensures that users will have a seamless upgrade/migration experience." (taken from softopedia.com)
This means that all the "vista compatible drivers" should work on win7 without any problems.
Nov 11, 2009 | Sony VAIO VGN-N250E/B Notebook
Sony VAIO VGN-250E/B upgrade memorey, will it take up too 4gb?
No the Sony VAIO VGN-250E/B has a maximum capacity of 2GB DDR2 RAM.
Oct 13, 2009 | Sony VAIO VGN-N250E/B Notebook
Sony vaio vgn-n250e laptop microphone problem
Good Luck.
Oct 24, 2008 | Sony VAIO VGN-N250E/B Notebook
Sony VAIO VGN-N250E/B Notebook Logo
73 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
