Question about Sony Qualia 006 70" Rear Projection HDTV
Hi there i have a 72" sony qualia sxdr and it shutdown by it self after few seconds, i was wondering if is the lamp ? and where is locate
    President:
  • Sony Master
  • 1,114 Answers
First, Check the fan. If it's dirty, it won't turn, and will cause the set to shut down. If it still will not turn on, check the "standby" light on the front of the set. If it flashes, it is a different problem, and may well be the bulb.
If you still have a problem with the set, check this site.
http://sites.google.com/site/sonylcdrptvproblems/#TOC-Optical-block-problems-by-TV-model
Sony has had lots of issues with the SXRD series since 2004. There have been a few class action lawsuits and a couple still pending.
Hope this helps
Posted on Oct 05, 2010
Sony Qualia 004 doesnt work i cannot turn it on.
Hi the problem is in the board GB, open the projector and find the GB Board an change only one component, the MCZ3001D! The board have two McZ3001D, only change the side position!
Apr 18, 2012 | Sony QUALIA 004 Multimedia Projector
After watching TV for a few hours it will turn off by itself. Then the light will blink 3 times. If this is the lamp door switch where is that located?
THERE ARE 2 SWITCHES IN THE TV THAT WILL GENERATE 3 BLINK SHUTDOWN ONE FOR THE LAMP DOOR AND ONE FOR THE LAMP ITSELF. I HAVE SEEN GENERIC LAMPS IN THE PAST THAT DON'T FIT QUITE RIGHT AND CAUSE THIS PROBLEM. OTHERWISE MAKE SURE THAT THE LAMP DOOR IS SECURE COMPLETLY.
Dec 16, 2010 | Sony Televison & Video
Tv keeps self restarting after about 30 - 45
When lamp in TV become weak in result and consume more current then its rating , TV gets that symptom, on for few seconds/ minutes, shuts down and turns on itself.
Please replace lamp in TV as procedure is written in user manual of TV and its easy.
Let me know if you have further question.
Thanks.
Dec 13, 2009 | Sony KDS-R50XBR1 50" HDTV
How to use the timer on a sony cyber shot 7.2mp digital camera
On your Cyber-shot DSC-W55 locate the control button:
32864f9.jpg Using the self-timer
Press cd9ebdc.jpg on the control button repeatedly until the desired mode is selected.
Conditions of the self-timer lamp:
(No indicator): Not using the self-timer
fc274e6.jpg: Setting the 10-second delay self-timer (picture is taken after 10 seconds)
996d00d.jpg: Setting the 2-second delay self-timer (picture is taken after 2 seconds)
Press the shutter button, the self-timer lamp flashes, and a beep sounds until the shutter operates.
Hope this helps.
Thank you.
Oct 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Qualia 005 compatibility with Blue Ray, AND where can I find a stand and a wall mount?
I may be sticking my neck out on this one, but I don't believe there is a way to improve the input resolution. If I'm right, the issue is not related to a firmware upgrade but the hardware design of the board and IC's on them. I have the same issue with a Toshiba 1920 x 1080 resolution TV.
The best you can do is to set the blu-ray to output at 720P which is actually higher resolution than 1080i. Here's why. 1080i is actually two fields of 540 resolution interlaced or put another way one 540 image overlaying a second 540 to make one complete video frame.
Still you make the call as to which one looks best to you
Apr 11, 2008 | Sony QUALIA 005 46 in. LCD Television
Sony LCD Projection TV turning OFF.....help!!!
Look carefully at the front lights. Usually when these sets shutdown they have a blink code on either the standby light or the lamp light. Update this with those counts. In the meantime, you may be seeing a problem with heat. If the lamp area gets too hot, the set will shutdown the lamp. Once the area is cool again, the lamp will fire.
Update this and we'll hopefully fix the both of them.
Dan
Apr 09, 2008 | Televison & Video
Sony Qualia and Sony XBR 4 TV
wow. mostly all new set from the last few years have a dual tuners
NTSC and ATSC and that would depend if or which set will get the better signal. Also remember that off air is analog and the sets are now design for digital.
Feb 09, 2008 | Sony QUALIA 005 46 in. LCD Television
Error Message
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
Aug 22, 2007 | Mitsubishi WD-57732 Projection Television
Sony Qualia 006 70" Rear Projection HDTV Logo
120 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
