Question about Emerson LC320EM9 32 in. LCD HDTV
I have a 32inch Emerson LC320EM9B lcd tv and it has a cracked screen. I took it apart to look at the connects froms the circut board to the lcd panel to see which connections are neccesary to get a replacment panel. I found this panel, http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260628039762&ssPageName=ADME:X:AAQ:US:1123 . The name is "32" Replacement LCD Panel CLAA320WA01 Chunghwa Chuanhwa". Comparing the photo to the back of my tv, they look very similar. However i cannot tell. Can anyone help me to see if this panal will fit, thanks!
  • 2 more comments
  • jmikelaitis0 Oct 05, 2010
    would this part number be one the back of the actual panel inside the tv or on the outside on the back of the tv?
    okay, i dont see any part number one the panel.
    yes it does have the metal shield behind it, ill try to take it off, i know the model number of the tv is LC320EM9B, so see if something comes up by searching for that? thanks -jordon
    okay, can i get back to you tomorrow with the corrct part number? thanks
  • 4,889 Answers
On the back of your tv's LCD panel, there will be a part number printed on a label or on the panel itself. Have a lok at it and see if it matches the one you have found on e-bay. If you cannot tell which one is the part number then get me all the numbers that are on the panel and i will tell you whats the part number and where you can get a suitable replacement.
Sai.
Posted on Oct 05, 2010
  • 2 more comments
  • eagle338
    eagle338 Oct 05, 2010
    On the back of the panel inside the tv.
  • eagle338
    Oh! Thats weird! Did you disassemble the panel from the tv? The panel has a metal shield behind it(in some models). You may have to dis-assemble that to find the part number. Meanwhile I will try finding the part number myself.
    Sai.
  • eagle338
    Yes run a google search for that part number . The ebay link you gave is the best deal you can possibly get. If the number matches you may wanna buy that right away. Usually replacement panels costs almost as much as the entire tv. Also just in case you still can't find the part number, then you may wanna get the service manual from the link below. It costs 12.99$ but it will help you with closure. Your Tv is listed as BLC320EM9 http://www.service-docs.com/store/catalo...
  • eagle338
    Yeah sure no problem :)
Cracked tv screen
its better throw it away rather than trying repair it. The panel is the costliest part of the tv.
www.electro-medical.blogspot.com
Nov 03, 2015 | Emerson Televison & Video
My tv will not stay on.model lc320em9b. tv will only stay on for about 2 minutes then goes off.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 24, 2015 | Emerson LC320EM9 32 in. LCD HDTV
I have a 32inch emerson flat screen has no power what can i do LC320EM2 A
Check the power board in your TV to see if there are blown capacitors. Before that check that all the cables are seated into the TV properly with plugin wall power.
Jan 21, 2015 | Emerson Televison & Video
What type of screw is needed to connect the bracket to the back of my 32inch emerson tv?
You would use vesa screws 4mm x 10mm - for non-recessed vesa mounting holes.
4mm x 20mm + approx 1ccubewi_0.pngm spacer - for recessed vesa mounting holes
Mar 28, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I have an Emerson TV Model #LC320EM9B about 1
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 10, 2010 | Emerson LC320EM9 32 in. LCD HDTV
My 32inch audiovox flatscrren will not come on but
Now in the front of the tv panel power blue light on and it solid green?Take ur tv aparts.The T-con board, this board sit in the botom in the middle of the LCD screen.This board is defective replaced it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-con board for the replacement.
May 11, 2010 | Audiovox FPE3205 32 in. HD-Ready LCD...
Can i get my 32inch ambilight screen fixed ,it has a crack on it .
Hi Raverbaby768,
I am Sorry that you LCD 32inch screen cracked.
and I Fear the costlies part of LCD TV's is the Screen.
Yes, the screen is the most expensive part of your entire TV. The cost of repair + transportation will likely equal to or exceed the cost of a new TV.
I would suggest you to try fixing the screen in the near service centre.
If my Solution is informative, kindly vote.
Regards
BEADHZ
Apr 09, 2010 | Astar LTV-32ASB 32 in. LCD Television
Trying to connect a surround sound system to my lc320em9b but no sound.
SORROUND SOUNDS SYSTEM ON TV DEPENDS ON THE TV STATION UV OPEN,U CAN HAVE IT IF UR WATCHING STATIONS HAVE SOUND SURROUNDS ON A PLAYER,W/ SOROUND
Feb 28, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I cracked my new 32inch lcd tv screen need new one
Don't know what brand it is but, it really doesn't matter the screen or lcd panel cost as much or more than a new set. Sorry.
Aug 24, 2009 | Televison & Video
Emerson LC320EM9 32 in. LCD HDTV Logo
452 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
