I have a Smart Drive Fisher & Paykel 7.5 washing Machine and my darks come out of the wash with hard to remove fluff
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.Now you need to remove the bowl and give the bowl and tank a good clean.1st remove the 2 screws under the lid that are hidden under 2 plastic caps at the front of the machine.Now lift the hob gently and lean it back against the wall.Now remove the agitator cap and undo the plastic wing nut inside your agitator.Once the wing nut is removed lift the agitator out of the bowl and put it on the ground.Now grab the inside of the bowl with a hand on the left and a hand on the right and lift the bowl gently out.Take the bowl out side and clean it with a hose and brush.After the bowl is clean it is the tanks turn to be scrubbed and cleaned.Use hot water only and a brush to clean the tank.Do not worry about the water getting into the tank as this will drain out once the machine is put back together.Be careful not to splash any water on the electronic buttons.Once the tank is clean and the dirty water is at the bottom of the tank refit bowl and agitator with the wing nut.Put the hob back down on the frame and refit the 2 screws and plastic caps.Now turn the power on to the machine and select a spin cycle and push the start button.The dirty water will now drain out and job done.Now you can use the machine as normal.Hope this is helpful and if you need further assistance feel free to reply back as I always check my profile for people who need help.Also if this helped could you please reply with a comment and a rating so I know I am making a difference.God luck with the machine and bye for now.
Posted on Oct 05, 2010
Fisher and paykel smart drive 5.5 won't start a wash cycle, no lights flashing or beeping looks normal but won't start
Contact Fisher and Paykel Service Center and DO NOT TRY TO OPERATE THIS MACHINE UNTIL CHECKED & VERIFIED BY AUTHORIZED FISHER AND PAYKEL SERVICE PROFESSIONAL.
Apr 28, 2014 | Washing Machines
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Fisher & paykel 501 smart drive washing machine
It does not seem like a problem of the unit. It might be a loose connection of supply code. Keep the supply code pressed to the unit in different directions and see if the unit takes power. If so, replace the supply code. It's not that expensive.
Jul 05, 2010 | Washing Machines
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Fisher & Paykel smart drive 708 filter
my machine swiches on but wont let it fill with water.
Any ideas?
adrian
Mar 17, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
