Question about Kenmore HE2 Plus Front Load Washer
We have a code coming up that says F33 and can't find a solution on line or what it even means....
  • 15,935 Answers
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
CLICK HERE
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa@#@#@#
Posted on Mar 04, 2011
Everytime i try to run a load of wash i get a F33 error - what can i do?
Please clarify the Model and Make of your Washer.
The F33 error for Whirlpool: The "F33" error code means that the washer has encountered a system error with the pump drive. The parts should be working fine; it is just the connection that caused the problem.
Check connectors on central control board.
Mar 09, 2011 | Washing Machines
I have error code f33 .What dose it mean and how do i fix it
F33 System leak
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Solution
  1. Make sure the hot and cold water lines are on and pressurized.
  2. Check for cracks or holes in the washer tub and pressure switch hose.
  3. Replace components if necessary. The pressure switch hose can have a pinhole in it and throw this code.
Feb 27, 2011 | Whirlpool WFW8300SW
What does F33 mean- its the code on my front loader washing machine
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore He2plus washer that gives me an error of F33
Thank you !!
Jun 19, 2010 | Kenmore HE2 Plus Front Load Washer
I am getting a S2 and a f33 fault and the washer is not draining what is the problem?
Hi, "F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Apr 10, 2010 | Kenmore HE2 Plus Front Load Washer
Error code f33 on an he4t
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 11, 2009 | Kenmore Washing Machines
Whirlpool duet sport. I am getting a f33 error code.
i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite he4t
really need the whole model # ?
1 pressure switch
2 flowmeter
3 CCU
4 hose
he F33 means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
May 20, 2008 | Kenmore Elite 45986 Front Load Washer
PANASONIC CU160C53XP
BEST WAY IS TO GET AHOLD OF THE MFR'S TECH SUPPORT LINE EASILY OBTAINED FROM YOUR SERVICE MANUAL OR INFO (NOT SURE OF STATE)
Dec 16, 2007 | Fedders A6P09S2A Air Conditioner
Kenmore HE2 Plus Front Load Washer Logo
64 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
