Question about Audio Technica USB Turntable
I buy Starlogic USB Turntable Model: 62904201 (E-E011) Serial: #:071100523 I Pay $149.00 plus Tax and no have CD software Driver for Install on my Computer so I need Help before send to garbage Help me Please!!!!!!
NEED A REPLACEMENT STYLUS FOR MODEL 62904201
Hi, I can supply a stylus for your Denon. Cheers John. Styluscity@gmail.com
Jul 29, 2011 | Denon DP200USB TURNTABLE W USB Turntables...
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
No cd + unknown model (china usb cam) and no driver i have
It would be cheaper to buy a new webcam than purchase the software just to find out the model number and required driver.
Aug 27, 2009 | I-O Data USB-CAM30MV Webcam
Usb audio driver won't install from original cd
Installing USB sound card (any windows)
  1. Do not connect or plug the USB sound card
  2. install the software and driver
  3. restart the computer
  4. connect the USB Sound Card
  5. windows found new hardware
  6. select find hardware automatically.
  7. if windows cant find the driver select browse CD (contain driver)
i have 3 soundcard installed in my computer (XP Pro SP2,Vista Enterprise,Ubuntu Linux) 1 built in and 2 USB.
built in I use for speaker, 1 USB I used for monitor to my DJ mixing software, 1 USB I used for telephone(VOIP)
Apr 02, 2009 | Crosley Traveler Turntable
Need driver for windows to have the Crosley CR249 turntable work correctly.
Insert the enclosed software cd into your computer.
Follow the instructions on the computer screen to install the software. If the software does not load automatically, browse the cd and open the Read Me folder for further instructions.
Connect the small end of the USB to the USB jack on the back of the unit.
Connect the other end to a USB port on your computer.
On your computer open the Record Recording software.
For instructions on operating the Record Recording software, browse the software cd and open the Read Me folder.
I got that from the manual. You don't need a separate USB driver for it, mate, but you DEFINITELY need the cd...
Hoping you have the cd,
Chris (ziraffa)
Dec 28, 2008 | Crosley CR249TA Turntable
Need a driver for FE-190
need a driver or cd to download my pic on my computer olympus FE 190
Mar 30, 2008 | Olympus FE-190 Digital Camera
USB driver for sony handycam
I need USB driver for sony handycam
Lost my CD software that comes with it.
Feb 21, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Audio Technica USB Turntable Logo
371 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
