Question about Moen 7835 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome...
We just installed a Moen Banbury songle handle faucet, and we have very little water pressue. The pressure in the rest of the house is fine, and we cleaned out the aireator filter. Any ideas?
  • 26 Answers
Hi jaryan--
Sometimes when you valve off a water supply, particles of rust or mineral deposits break free and travel along down the pipe when the water comes back on, only to stop when they reach a small opening. In this case, it could be the faucet's supply line.
You already cleaned the aerator, which would have been my first suggestion. The next step is to visually inspect the supply lines for the faucet. Are any of them kinked or twisted? If they look good, the next step is to valve off the water at the shutoff valves closest to the faucet-- they should be on the plumbing under the sink.
Next, disconnect the supply lines to the faucet at the point closest to the faucet. Using a bucket, aim each supply line, one at a time, into the bucket and slowly valve on the water. How is the water pressure? Do any rust particles come out? Flush each line until the water runs clean and strong. Before you reattach the supply lines, use a flashlight to check the hardpiping on the faucet itself and visually check for any obstructions. Remove any suspected blockages manually.
Reconnect the supply lines to your faucet and check its pressure again. If the faucet's pressure is still low, you may have a clog in the faucet's interior mechanism.
--Hope this helps
Posted on Oct 07, 2010
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 117 Answers
Same problem with our Kitchen Faucet. I tried the common/easy solutions (aerator, cleaning the supply lines, etc.) No go. Then I got a lead on another common problem that can cause this. If you have a vegetable sprayer, the diverter might be getting stuck and this will reduce the volume coming out of your faucet head. You can either replace the diverter or try to lubricate it with plumber's grease (not too much though!). I tried to replace the diverter, however the older one was "frozen" on. A little plumber's grease has at least increased the volume - perhaps the diverter is not getting stuck half way anymore. btw: To see about a video on how to reach those got awful water shutoff valves under your sink, go to this link: http://prismreachingwatersupplyvalves.blogspot.com/
Posted on Mar 06, 2015
Moen Kleo faucet. Handle loose, removed set screw to tighten but now no water pressure. (it worked fine before inspector came for house sale)
Something always seems to happen when an inspection is due. The handle tightening operation may have affected the cartridge inside. Back off the screw and water may return. If not, the cartridge may have to be replaced.
Jun 30, 2016 | Moen Plumbing
How do I fix hot water handle that is leaking on Moen Banbury ca87000 sink
The valve cartridge needs replaced. Those can be purchased at most home improvement stores, such as Home Depot. Or, it may be under warranty.
http://www.moen.com/replacement-parts/search
Nov 17, 2014 | Plumbing
Moen banbury faucet repair
I had a look at the installation guide and exploded diagram, It seems that the whole assembly will be tightened when the mounting nut is put on.
The links to the installation guide and exploded diagram are:
http://www.moen.com/shared/docs/instruction-sheets/ins2224.pdf
http://www.moen.com/shared/docs/exploded-parts-views/87017pt.pdf
Jan 18, 2014 | Plumbing
We just installed a Moen Banbury single handle faucet, and we have very little water pressue. The pressure in the rest of the house is fine, and we cleaned out the aireator filter. Any ideas?
Yes, Pull the faucet and look for particluate matter in the water passageways. Also check your shutoff valves, they have washers that fail, and then break up with you shut them off for faucet replacement, and little pieces get flushed into your new faucet....Kind of a common issue.
Oct 05, 2010 | Moen Plumbing
Please Help! I installed 3 Moen Banbury single handle faucet/shower units. Water will not flow from either the hot or cold handle position from any of the units. I pulled a feeder pipe (pex) off each one...
were there any thread protectors inside the hot and cold inlets? sometimes they put Styrofoam pieces inside to keep debris out of the inlets and outlets. inspect inside of valve body through inlet holes thoroughly
Sep 16, 2010 | Moen & One Handle Tub & Shower Faucet
No hot water on Moen single handle shower faucet. cold ok and shut off is fine
do you have hot water elsewhere? if not, might be that your water heater is not heating.
if you do have hot water elsewhere, did you let the faucet run for a minute or 2.
did you have hot water before? is this a new house? new valve?
need a little more detail.
on posi temp valves, if there were no water coming out of the hot side of the valve, the valve will not operate.
Aug 12, 2010 | Moen 1 Handle Lever Shower Faucet With...
My moen vestage faucet is dropping water pressure. It worked fine when it was installed but the water volume out of the faucet has dropped to less than half of what it was.
Have you removed aerator ,screen etc., from end of tap, to see how flow is with it off. If good, or same as other taps when taken off of them, then you've got debris in aerator, and screen.
Jan 03, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Only hot water/ little pressure
You must of turned off your water to the house or maybe it was turn off in the street recently because it sounds as if you have debris in you strainer remove the head and rise of removing any dirt rise out both front and back of shower head while head is off run shower to make sure you are getting full pressure out of the pipe that the head is connected to
Jul 11, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen 7835 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
511 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
