Question about Viking DCWH Kitchen Hood
The hood is displaying "filt" so i assume filters need to be changed. i tried to push up on it to try to release the metal grill panels but the fan motor is positioned too low keeping me from pushing it high enough to release the panels. is there a screw or some trick movement to release it?
2 Suggested Answers
  • 72 Answers
SOURCE: the kitchen hood fan above
Check the filters first, if they carbon filters are older than a year then replace. If a charcoal filter is fitted also replace this.
Posted on Dec 28, 2009
My 1999 tyahoe hood latch and cable doesnt work how can iopen the hood
have someone push down on hood and try to open ---- reach behind the lever and disconnect cable use a vise grip to pull cable if cable is broken---- than behind grille is latch look through grill and will need a metal hook to grab cable and pull cable towards grille and pull through cut cable cover back and pull cable back
Hood latch won release ChevyTalk FREE Restoration and Repair Help for your... how to open hood from outside when cable breaks
Jul 28, 2016 | 1999 Chevrolet Tahoe
My hood safety latch want release the hood so it can open. How can I get around this
You will need to use a long tool and some spray lube to get it to pop. Have some one hold up on the interior latch while you try 'slapping down' on the front of the hood with your hands and if that doesn't work, try the spray through the grill area. Use the long tool with a flashlight to try pushing the latch from the grill area. Good luck!
Sep 13, 2015 | 2005 Chrysler Pacifica
Bentley gt bonnet release
Pop opens the hood
Pull or push the hood release until you heard the hood pop opening whether the hood release is inside your vehicle. However, you need to look anywhere for 2013 Bentley Continental GT W12 and through the grill, carefully feel under the grill and finally behind the bumper to find a lever, arm, button or handle if the hood release is apparently at the front. And then press, pull or push it from the front to back, side to side until finally it can release the hood.
Even though the hood will just open a tiny, it will possibly be stopped by a safety catch which is a metal lever. You should release the hood when you pressed one way or other in order to open all the way. When you are driving, this gizmo accidentally avoids opening the hood.
Raise the hood fast with one hand
Feel along the station between the grill and the hood for the safety catch with the other hand. The rest of the way is to release and raise the hood.
If it is necessary, secure the hood
It is fine if the hood can stay up easily all by itself for 2013 Bentley Continental GT W12. Only if it does not like that, you should have to find a hoop prop which is a thin and long metal rod attached to the bottom edge of the opening hood or to the underside of the hood. In other words, either lift or lower the rod and fit the finishing of it into the slot which is provided to hold it.
https://electronicshelponline.blogspot.com/
Mar 03, 2012 | Bentley Continental GTC Cars & Trucks
The hood will not open on my 2002 subaru legacy. can you help me?
try having someone hold the hood release open while you lift the hood. sometimes if you push down first then up it will release. If there is no way to get it open you might try to see the bolts through the grille to unbolt the hood latch through the
grille. If you cant get to it that way try to come from the bottom. Sometimes you can put a long screwdriver through the grille opening and reach the hood latch where the cable hooks and pry it the same way the cable would pull it. If you cant get it through the grille you will have to come from the bottom with a long screw driver to reach the hood latch at the radiator support and find the latch release action. you will have to remove some splash covers under the rediator support.
Dec 15, 2010 | 2002 Subaru Legacy
How do i change a headlight
1.FACE THE VEHICLE SO THAT BATTERY IS ON YOUR RIGHT;
2. REMOVE THE BLACK PLASTIC PIECE THAT RUNS OVER RADIATOR BETWEEN HOOD LATCH AND FAN. IT IS ABOUT 53 1/2" LONG AND HOLDS THE HOOD PROP CLIP. (3 PLASTIC PUSH RETAINERS & 2 SHEET METAL SCREWS);
3. REMOVE THE GRILL ASSEMBLY UNDERNEATH THE PIECE IN STEP 2 BY PUSHING DOWN FIRMLY ON 4 RETAINER CLIPS WHICH RUN ALONG THE TOP. USE A WIDE SLOT SCREWDRIVER. PULL UP GENTLY ON GRILL ASSEMBLY. IT WILL POP OUT. THE GRILL ASSEMBLY EXTENDS UNDER EACH HEADLIGHT ASSEMBLY (HA) AND IT DISPLAYS THE CHEVROLET LOGO IN THE MIDDLE. MY GRILL ASSEMBLY POPPED OUT EASILY AND ALL THE OTHER RETAINER CLIPS ON THE BOTTOM AND BENEATH AND TO THE SIDE OF HA WERE AUTOMATICALLY RELEASED WITHOUT ANY FUSS;
4. ON TOP OF HA SEE ONE TAB (ABOUT 1" LONG)ON THE RIGHT SIDE AND ONE ON THE LEFT (THE ONE ON L IS CLOSER TO THE FENDER);
5. PULL UPWARD DIRECTION ON TABS. THEY WILL SLIDE UPWARD A COUPLE OF INCHES AND WILL RELEASE THE HA WHICH YOU CAN THEN PULL OUT TOWARDS YOU;
6.AT BACK OF THE HA, REMOVE 2 ROUND RUBBER CAPS (ABOUT 4" IN DIAMETER)--ONE FOR LOW BEAM--ONE FOR HIGH. REVEAL BULBS. UNSNAP THE WIRE HARNESS FROM BULB BASE AND TURN BULB 1/4 TURN CLOCKWISE (REMEMBER YOU ARE FACING THE TRUCK)
7.REPLACE BULB(S). #9006 BULB IS GRAY-BASE, FOR HIGH BEAM ON OUTSIDE. #9005 IS BLACK-BASE, LOW BEAM TO INSIDE OF HIGH BEAM.
CHANGING HIGH AND LOW AND REASSEMBLY TOOK ABOUT HALF HOUR. GOOD LUCK.
ALTERNATIVE:
IF YOU ARE REPLACING THE PASSENGERSIDE HEADLIGHT JUST REMOVE THE AIR FILTER COVER AND PULL PLUG OUR FROM BEHIND HEADLIGHT AND REPLACE. BE CAREFUL HANDLING LIGHT BULB.
TO CHANGE THE ONE ON THE DRIVER'S SIDE JUST REACH IN FRONT OF THE BATTERY TO ACCESS THE PLUG AND HEADLILGHT. TOOK ABOUT 5 MINUTES. ENJOY YOU TRAILBLAZER, GREAT TRUCK.
Thank you for using fixya
Jun 12, 2010 | 2004 Chevrolet TrailBlazer
2004 Chevrolet TrailBlazer. Passenger front low beam headlamp out
2.REMOVE THE BLACK PLASTIC PIECE THAT RUNS OVER RADIATOR BETWEEN HOOD LATCH AND FAN. IT IS ABOUT 53 1/2" LONG AND HOLDS THE HOOD PROP CLIP. (3 PLASTIC PUSH RETAINERS & 2 SHEET METAL SCREWS);
3.REMOVE THE GRILL ASSEMBLY UNDERNEATH THE PIECE IN STEP 2 BY PUSHING DOWN FIRMLY ON 4 RETAINER CLIPS WHICH RUN ALONG THE TOP. USE A WIDE SLOT SCREWDRIVER. PULL UP GENTLY ON GRILL ASSEMBLY. IT WILL POP OUT. THE GRILL ASSEMBLY EXTENDS UNDER EACH HEADLIGHT ASSEMBLY (HA) AND IT DISPLAYS THE CHEVROLET LOGO IN THE MIDDLE. MY GRILL ASSEMBLY POPPED OUT EASILY AND ALL THE OTHER RETAINER CLIPS ON THE BOTTOM AND BENEATH AND TO THE SIDE OF HA WERE AUTOMATICALLY RELEASED WITHOUT ANY FUSS;
4.ON TOP OF HA SEE ONE TAB (ABOUT 1" LONG)ON THE RIGHT SIDE AND ONE ON THE LEFT (THE ONE ON L IS CLOSER TO THE FENDER);
5.PULLUPWARDDIRECTION ON TABS. THEY WILL SLIDE UPWARD A COUPLE OF INCHES AND WILL RELEASE THE HA WHICH YOU CAN THEN PULL OUT TOWARDS YOU;
CHANGING HIGH AND LOW AND REASSEMBLY TOOK ABOUT HALF HOUR. GOOD LUCK. ALTERNATIVE: IF YOU ARE REPLACING THE PASSENGERSIDE HEADLIGHT JUST REMOVE THE AIR FILTER COVER AND PULL PLUG OUR FROM BEHIND HEADLIGHT AND REPLACE. BE CAREFUL HANDLING LIGHT BULB. TO CHANGE THE ONE ON THE DRIVER'S SIDE JUST REACH IN FRONT OF THE BATTERY TO ACCESS THE PLUG AND HEADLILGHT. TOOK ABOUT 5 MINUTES. ENJOY YOU TRAILBLAZER, GREAT TRUCK.
Feb 20, 2010 | 2004 Chevrolet TrailBlazer
Need to get under hood hood release doesnt open hood
Hello. I recommend that you start by having a friend help you push down on the hood at the same time you try to pull on the release. If that doesn't work, it may be possible to grab the release cable from under the car and release the hood. Otherwise, you may end up having to remove the grill in order to get to it, not a fun job at all. All of that said, drive it to a Walmart and have the oil changed. If they can open it to change the oil, ask them how to they did it and have them lubricate the hood release while they are at it. Good luck with it.
Nov 23, 2009 | 1990 Toyota Tercel
How to change carbon filter on whirlpool cooker hood AKG958GY
The paper filte pulls out from under the lugs of the metal panel that is attached to the door, turn the plastic clips on the left and right, half way and it will drop out.
Sep 14, 2009 | Kitchen Ranges
Fan Grill is discoloured
try contacting the manufacturer, or the supplier via heir website, or local repair agent. i use nappi-sand, and soak overnight, if their discolored, the naip-sand or like restores them.
Jan 27, 2009 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
2001 Jetta tdi hood release broken how do i get it open
on the left side of the drivers side their is a panel with the hood release Pull off the cover of the hood release and you will see a cable connected to the hood release. take some pliers and give it a good pull.
if you dont hear a click, have someone pull the hood up while you pull on the hood release cable. next their will be little space to take off the grille for easier acces. take off the grille carefully by prying it off carefully on each side. push the grill up and pull it towards you going up then down.
Now all you have to do is stick a flathead screwdriver or philips. and on the bottom of the hood release on the hood stick the screwdriver under the release and push the screw driver down while pushing the hood up.
Dec 07, 2008 | 2004 Volkswagen Jetta
Viking DCWH Kitchen Hood Logo
82 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
