Question about Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W
Danby DCF401W freezer is not working properly. If I plug in, it seems working but the temperature is not absolutely low enough to be frozen even though I turn the switch all the way to the right, and I hear water flow sound all the time from inside of the machine.
  • 98 Answers
1. There can be a low gas problem.
2. Switch can be out of order (It switch off quickly).
You may need repairs.
Posted on Oct 06, 2010
Power failure. Seems to be dead; even the pilot light is off.
Check socket, fuse and mains cable. Check on/off switch, then thermostat and compressor relay. If power to all of these it is the compressor at fault.
Apr 14, 2012 | Danby 3.6 cu. ft. / 102 liter Chest...
Unsure how the temperature dial goes. Is it l. or r. for colder?
Hi Normally temperature dial has at left maximum temperature while right is minimum temperature.
You can feel ( hear ) actually the sound of motor/compressor when it is run. Running motor will produce low temperature. By this you can decide where the set point should be made
Sep 09, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
SETTINGS DCF520W
The best temperature for storing food is 0 degrees F. I would go to Wal-Mart, K-mart or a dollar store and find a refrigerator/freezer thermometer and set the freezer temperature with that. Best of Luck
Mar 10, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Wiring diagram for danby thermostat freezer
Doesn't matter thermostat is just a switch operated by temperature.
Jul 10, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Would a bad thermostat cause my danby to not completely freeze?
Should operate 24 hours before putting anything in that is not already frozen. Check it again after it has run for 24 hours. Anytime you adjust the thermostat go one click at a time and wait 24 hours for it to stabilize.
eric
Jun 30, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Danby freezer not freezer
If it is the thermostat that is defective the two wires that go to the thermostat for compressor operation can be connected together which would power up the compressor. Unplug the unit before attempting to connect the two wires. after connection is made plug it back in and if the compressor operates and the freezer comes down in temperature you definitely have a bad thermostat.
Jan 23, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Green light on the front
Your problem is more than likely in the light itself. The green light is the indicator that the temperature is in acceptable range.
May 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
428 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
charles
Are you a Danby Freezer Expert? Answer questions, earn points and help others
