Question about Refrigerators
I have a sub zero dual refrigeration dual system 680. I have a light on that says vacuum condenser. What do I do.
    Sergeant:
  • 239 Answers
Pull top grill off and vacuum coils of in there
Posted on Oct 24, 2010
Sub-Zero 680/F The fridge is flashing "service"
Not filter but condenser coil thathe is next to compressor. Clean it out then check unit operation
Jan 26, 2018 | Sub-Zero 680 / F
Vacuum condenser light is blinking and no ice is being made.
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />If your refrigerator is running but warm, then&hellip;</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><span style="mso-tab-count: 1"> </span><br />Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...<br /><br />Refrigerator Condenser Coil Cleaning Refrigerator Repair<br /><a href="http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning" target="_blank">http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning</a><br /><br />Refrigerator Troubleshooting Refrigerator Compressor<br /><a href="http://www.fixya.com/support/r3885294-refrigerator_troubleshooting" target="_blank">http://www.fixya.com/support/r3885294-refrigerator_troubleshooting</a><br /><br />Refrigerator Compressor Start Capacitor and Start Relay<br /><a href="http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor" target="_blank">http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span>
Aug 26, 2010 | Sub-Zero 680 / S
Sub Zero model 680 F, inside ref area seems damp. Food also has moisture in ref section.
the air should be dry and packages not wet . I would think the defrost cycle is not working properly . may have a drain pluged or a defrost timer that is not supplying the power or the defrost terminator is cycling off at too low a tempt . . most common would be the terminator . . ck the drain and replace the terminator . there is also a drain heater that can be install if you find that to be the problem .. ..and when doing all these things clean the cond coil up on top where the fan cools the compresor . very imporant. mm
Aug 12, 2010 | Sub-Zero 680 / F
Cleaned condenser on sub sero 680f and now fridge is running high
Check to see if the condensor fan (underneath the refrigerator) and the evaporator fan (behind a panel in the freezer) are both running. If one of these is not running, the refrigerator will not have its full efficiency.
Oct 18, 2009 | Sub-Zero 680 / F
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 680 - vacuum condensor message won't go away.
You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that should clear the fault code.
Aug 16, 2009 | Sub-Zero 632 / S
Where are the coils on a sub zero 680? Vacuum condenser signal
Hello.
On the top of your unit there is a grill. Open both door and look at the lip under the grill. Remove these four screws. Now, pull on the top of the grill. You will notice that it is held on by two springs. Unhook those springs and set the cover aside. The coils are on the right hand side. Use a vacuum with the soft brush attachment to clean them and avoid damaging the airflow. Also, check the fan on the other side of the coils to make sure it is running.
Jul 16, 2009 | Sub-Zero 680 / F
601R sub zero vacuum condenser notice
Your problem might be serious enough to warrant a repairman's visit. But this was my experience: An official Sub Zero repair company in NYC told me this: If the "vacumm condenser" light keeps flashing after you've opened and cleaned the condenser grill, then either pull out the plug for the Sub Zero refrigerator or turn off the circuit breaker (or fuse) in your house that leads to it, wait for some minutes and then turn back on. It is NOT enough to turn off the unit using its own internal on-off switch - it has to be totally disconnected from the AC. I did so, waited 15 minutes, turned back on, and it worked!! I had vacuumed the condenser grill twice but the "vacuum condenser" light kept flashing AND the refrig would go bonkers if set below 38. Now the flashing warning is off and it's down to 35. Great !!!
Jun 27, 2009 | Sub-Zero 601R
Sub zero vacuum condenser
Top of grill is held by a spring. Pull out the top and lift the grill to remove. It can then be dropped down out of your way.
Jun 01, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
