Question about Acer AL1916W 19" LCD Monitor
Acer ali916w monitor acer symbol blinks on black screen a long time before windows starts
  • 198 Answers
SOURCE: 1inch black line down right hand of screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Fix-4U
  • 293 Answers
SOURCE: black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Posted on Sep 08, 2008
Fix-4U
  • 293 Answers
SOURCE: Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Posted on Dec 18, 2008
budmrtn
  • 11361 Answers
SOURCE: My Monitor worked great for the last year or so.
More likely to be bad caps in the power suppl;y, see example here: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 06, 2010
jmgldsmth
  • 2005 Answers
SOURCE: Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Posted on Jul 22, 2010
The screen on my acer asire/E won't turn on even though it is powered on.
could be what they call the inverter thats gone..or your screen has gone..to find out if its your screen thats faulty just put another monitor to your laptop using a vga cable ,if your windows show on the monitor then its your laptop screen or the inverter thats gone.
Apr 20, 2014 | Acer Aspire One PC Notebook
Sony vaio tr3a screen is black, but safemode lettering shows when I reboot with f 8 held down so I know the monitor is working but when I choose safemode and the computer tries to get into windows...
Hi ponotoc2,
On my acer I have some F buttons with little symbols on, I know that if I press FN + F6 it will switch my laptop screen on and off, I also can use FN + F5 to swap between monitors.
These could be different on a sony though and I can't remember what F numbers you need to press, I've seen some people say FN + F4 but im not 100% sure on this..
The symbol you should be looking for could look like 2 boxes one dark one and one coloured to simulate brightness.
I hope this helps
Myke
Feb 23, 2011 | Sony VAIO TR3A Notebook
Jul 22, 2010 | Acer AL1917W LCD Monitor
The computer boots but there's no display
check the display properties for dual monitor settings in
display properties>settings> check all options
I think it is set for external display u change to dual display. then both displays can work. or there is some display symbol of some function key. check that and press
Jun 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer 4650 Travelmate Black screen
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer TravelMate 3260-4874 Notebook
Tower is beeping and monitor on/off switch is blinking
I have not solved the problem of the blinking on off switch, but I have solved the problem of the monitor attached to my laptop waiting so long to start up. I never shut down the computer and I never hibernate it either. I leave it on 24 hours a day.
May 19, 2009 | Acer Computers & Internet
Blank screen
Possible that the HV inverter or the CFL tubes are going bad / defective. I suggest to bring the unit to an authorized Acer service center for proper check-up / test & fix the problem. regards
May 16, 2009 | Acer X221WSD Monitor
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
My monitor will only blink a black or white screen.
check the warranty online for your screen.. go the the acer support website and look up warranties, and it will ask for a really long number on the back of your screen, and it will tell how long the warranty is good for and what to do with it.
Mine is doing the same thing. flashes white then black and that is all
Dec 31, 2007 | Acer AL2016WBbd Monitor
Acer AL1916W 19" LCD Monitor Logo
144 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
