Question about Panasonic NN-T994SF Microwave Oven
We have a NN-TKD51 Microwave trim kit we have had in storage for a long time and are wanting to use it. What size cavity do we need and how do we assemble it?
MicrowaveSvc
  • 9047 Answers
SOURCE: looking for a G.E. microwave trim kit
Your best bet is to call GE Parts & Accessories at 1-877-959-8688
(Mon-Fri 7am - 6pm CST, Sat 7am-4pm CST)
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Need door assembly diagram to
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
SOURCE: Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Posted on Nov 22, 2008
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
SOURCE: Need replacement microwave for 6 yr. old Thermador MBBS microwave
I have the Thermador MBBS/01 in a Theramdor oven/warming drawer/microwave unit. When I was told it would be $600 to repair it, I called thermador & they don't make a replacement. Thermador CS was even rude about it. I searched & searched for a microwave that would fit & found a GE model JEB1860M1SS at Home Depot for $259.00. My husband & I just installed it & the frame kit inside, on the old Thermador micorwave fit PERFECT! I could not believe it. I thought we would either have to settle for something looking tacky in the hole or buy a whole new unit. Looks like it came in that unit.
Posted on Mar 27, 2010
Can panasonic microwave oven nn-cf771s be built in to kitchen unit?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 05, 2016 | Panasonic NN-CF771SBPQ
Hi my oven suddenly started making loud weird noises and now does not heat any food. I smell smoke. What might be wrong?
Seems to me that your magnetron is a goner, check also the antenna shield, cover inside the oven cavity and replace both, you may need to clean and repaint burn surfaces inside oven cavity.
Jan 08, 2016 | Panasonic NN-S676BA Microwave Oven
I just want a new one--what size replaces it
Take a measuring tape measure all four criteria, then when you go to buy, match the measurements on the box and have a salesman give you a hand so there can be no errors.
Apr 02, 2012 | Jenn-Air JMC7000 Microwave Oven
WHAT IS THE MAX TEMPERATURE THIS MODEL CAN SUSTAIN NN-CS599S LET SAY I WANT HEAT THE SUBSTANCE FOR 300 CELCIUS FOR 10 MINUTES..HOWEVER THE OWEN REACH THE SET TEMP AT FIRST 5 MINUTES....IS IT THE OVEN CONT...
I do not know of ANY microwave that will get you anywhere near 300 celcius, the cavity thermals are rated around 110.F and even the mag limit thermal of the comercial units are 300F No where near the celcius temps you are talkig about.
Sep 15, 2017 | Panasonic NN-SN657S Microwave Oven
Beeping at night
if it beeps you might as well just unplug it
Dec 08, 2008 | Panasonic NN-C994S Convection/Microwave...
Nov 21, 2008 | GE JE1640 Microwave Oven
Trim kit
These are countertop units. If you do enclose it, be sure you ventilate it adequately. If is not designed to be enclosed.
Dec 15, 2007 | Panasonic NN-H965 Microwave Oven
Installation Advice
The trim kit would be passively vented. I would contact the manufacturer's customer service peoiple for details. You may also need to ask to speak to a technician if the customer service folks can't fully answer your inquiry. See http://www.baumatic.co.uk
Apr 18, 2007 | Baumatic BTM25SS Convection Microwave Oven
Panasonic NN-T994SF Microwave Oven Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
