Question about Dishwashers
When you start it up the water doen't come on. Wife said she her some noise and smelt something. When I push the rinse function nothing happens. When I push the drain function I hear the drain motor working. I think the problem is the water pump, If you agree how do I change it?
  • Dishwashers Master
  • 43,501 Answers
The valve that let's the water in is an electrically operated soleniod valve. there is an electric coil that opens and closes the valve. This coil probably burnt out and caused the noise and smell...the water is pushed into the dishwasher by the house pressure there is no pump to pump the water in...the pump will not run to spray the water around if it does not sense that there is enough water in the dishwasher...
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Oct 05, 2010
Will not start
It seems that something was burned out trying to make the starter turn. The problem could be the starter and/or the solenoid.
Go to youtube and enter, "how to check a starter" you may have to remove it to check it. I could tell you how. But it is better if you see how it's done for yourself. Also check the fuses.
Mar 21, 2014 | 1987 Chevrolet Corvette
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Loud whirring noise going into rinse cycle. Low
Hi tuck just read your posting.Now on the low whirring noise on the start of the rinse cycle ,Is it when the machine is draining the water or filling with water.If the noise happens when the machine is draining then I think either your pump has something slowing it down or it is faulty.Please look underneath the machine to the front right and you should see a red or black fan .If you do then this is your pump.If you don't see a fan you must have the newer style of pump.Please reply with additional information on the questions and I am sure I can help you rectify this problem
Jul 08, 2010 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool electric dryer wont start
sounds like the drum guides are worn or bearing is worn
Jun 11, 2009 | Dryers
My washer stops after its done washing and does not rinse.
you probably have a clogged water pump you might check it out
Jan 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool gold UIltimate care heavy duty super capacity washer
Well you can check the capacitor with a meter for farads, but it sounds like you have a clutch and/ or gearcase failure causing the motor to overheat. The second thing to do is unplug the washer and check the timer. I would right after the agitation to inspect for heat and burnt connections.
Oct 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Jun 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Model LW6501W2
Sounds like the outlet pump has siezed up due to having been stood for so long. You may need to take the pump apart, clean the shaft & reassemble. Or, you could try a spray with WD 40 on the pump. TURN POWER OFF FIRST
Oct 26, 2007 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
Owen Barnes
