Question about Dryers
I have a Whirlpool Ultimate Care ll Dryer. (Electric) It wont The power terminal is getting power.
  • Dan Webster
    Dan Webster Oct 05, 2010
    Model number pwease?
  • 5,911 Answers
If your ELECTRIC dryer is still running, but does NOT produce heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
IMPORTANT NOTE: Your problem may or may not be related to a heating element problem as there are numerous factors that can cause a dryer not to heat. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. If the model number you have listed is correct, your heating circuits are behind the rear panel on the right-hand side.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) may be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify any parts you may need. The heating components are usually listed under the "Bulkhead" section.
If you have any questions, please post back and let me know. I hope you find this information helpful.
NOTE: If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.
Posted on Oct 05, 2010
My whirlpool ultimate care II electric dryer won't
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 21, 2011 | Whirlpool Dryers
Whirlpool Ultimate Care clothes dryer heater does not come on
First verify you have 220 volts of power at the terminal block on the rear of the dryer.
If power is OK use your volt meter set for continuity and check the door switch. With the door closed it should get a reading.
Finally,remove the rear panel from the dryer and check the thermal fuse located on the left of the main exhaust duct. It is about 1 and 1/2 inches long by 1/2 inch wide and white in color.
Remove the 2 wires and check for continuity with the meter.
No continuity is a bad fuse.
It is replaceable,not re-settable.
Sep 03, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer wont work
Probably have an open fuse. take off the back and by the exhaust is a skinny white fuse. jump the wires together and see if dryer will work. Replace it if so.
May 28, 2010 | Whirlpool LER5636P Electric Dryer
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
Whirlpool Ultimate Care II Dryer timer knob
The timer cam is not aligning the internal switches. Replacing it is the only fix.
Eric
Sep 17, 2009 | Kenmore 62602 Electric Dryer
Ultimate care ll
Either the bleach is being put to the clothes too early, or too much laundry at one time and the bleach cannot mix properly. Check a small load to see if you get the same results
Jul 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
Jan 23, 2008 | Dryers
Dryers Logo
57 people viewed this question
Top Dryers Experts
