Question about Bunn RTF Coffee Maker
Will not make hot water. This machine is an auto feed. The water will process through the filter, but the water is only luke warm.
    President:
  • 1,618 Answers
Sounds like the hi-limit thermostat on the boiler is damaged, also check to make sure thermostat is set correctly.
Posted on Oct 06, 2010
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
I have abosch 1600 ps aquastar 4.3 gpm indoor when i turn hot water on it all fires up but no hot water comes out only luke warm water why
Water heater is heating water but only luke warm water arrives at faucet.
Open TP valve and confirm that hot water is available.
If water at TP valve is hot, then problem might be plumbing-related, for example crossover.
http://waterheatertimer.org/Crossover.html
Aug 15, 2011 | Bosch 1600PS NG Aquastar 4.3 GPM Indoor...
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
My jAYCO rv only get luke warm water for as few seconds and
Also check that by-pass valve(s) is/are, in proper position at back of tank.
Apr 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hot water on bathroom faucet won't get hot only luke warm
That is a type where the water is mixed inside the valve and the valve has gotten worn or loose inside. Replace it or take it apart to see what isn't working properly.
Apr 12, 2010 | American Standard Bath Faucet Ceramix...
Extreme hot water then to consistent luke warm
Possible thermostat problem. Are you experienced enough in that area to do some testing. Have a multimeter? If not experienced, don't try it, too dangerous. Call in a service person.
Mar 07, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Why is my warm water is cold? The hot is hot and cold is cold but warm is cold.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
Jun 28, 2009 | Admiral AW22 Top Load Washer
Water Flow
disconnect your hoses and check for pressure without connected o machine, then check with int he water inlet valce for a clogged screeen slowing the pressure
Jan 25, 2009 | Roper RTW4300SQ Top Load Washer
Heater will only heat spa water to luke warm.
sounds like it may be the thermostat on the heater. You are correct to check the filter first. if it is clean then it is probably the thermostat
Dec 19, 2008 | Jandy Laars Lt 250,000 Btu Heater
Bunn RTF Coffee Maker Logo
70 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
