Question about Dishwashers
I have Kitchen Aid Dishwasher Model # KUDMOITJBLO. We began having trouble with the top rack coming out of the brackets on the upper rack track. Kitchen Aid sent me 4 parts # 8268785. The problem is that the brackets that they sent have wheels on them. I don't know how to get them into the track. A call to Kitchen Aid got me no where. They claimed that they don't sell parts so therefore they could not help me (with the parts that they sold me). The situation has gotten progressively worse. Now the top rack will not stay in place at all. Is there any way that I can install these new brackets. Thanks, Paul
  • honeydoit Aug 01, 2008
    I have a similiar problem, however my model number in KUDI01FLSS6. The top rack rails of my unit ride on stationary wheel brackets. I have the replacement brackets but I am not sure how to remove the old brackets and install the new ones. There are no existing screws or clips on the new brackets. HELP!!!
  • Anonymous Mar 28, 2014
    kichenaid dishwasher w103111. The wheels on the top rack broke. I bought replacement parts but am unsure how to dismantle the broken piece from the top rack. Thanks.
I removed the tracks from inside the dishwasher.  Then I was able to carefully remove the endcaps (something I had not been able to do previously) carefully.  The existing broken wheels slid out and I slid two new brackets into each track.   If I attached the tracks to the rack first, I would not be able to clip them into place, so I first replaced the endcaps and then returned the tracks to their positions inside the dishwasher. Reattaching the upper rack is not difficult, but takes two people while I connected the left side, my assistant supported the rack on the right side.  I then connected the right side of the rack.  I slide the rack back and forth to macke sure that is worked smoothly.  We then loaded the dishwasher and washed our dishes as we had in the past.
Posted on May 29, 2008
Dishwasher rack falls off
Could it be that KitchenAid wants you to replace the entire rack? Check with a local appliance parts supplier if you can because the roller must be a hot replacement item.
Nov 21, 2013 | KitchenAid KUDS30IXSS Builtin Dishwasher
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
Top rack of dishwasher does not work
make sure that the tracks are clean on it to roll in and out of.
Dec 27, 2012 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Need part no. 9741982 Upper Rack for my Kitchen Aid dishwasher. It is a discontinued item. Where can I find one?
My mom bought new racks for her dishwasher and now her dishwasher has died. I have both an upper anda lower if you are still looking for one.
Dec 10, 2010 | Maytag MDB3100 Dishwasher
Kitchen aid dishwasher, 3 yrs old, dishes on top rack do not get clean
On your model, upper rack cleaning issues are most often linked to debris in the inlet to the pump. I have put some instructions together on cleaning this. If you follow the link it will explain how to check and clean this.
Sump Clean Out
Aug 22, 2010 | KitchenAid Dishwashers
My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Jun 20, 2009 | KitchenAid Dishwashers
Kitchen Aid SS Dishwasher KUD102CRBS1 - Top Rack has 3 rusty spot
Looks like you can get the upper rack for about half that, direct from Sears-
Dishwasher Dishrack Upper Part Number 8539234 Sears PartsDirect
Still kinda pricey if you only have a few bad spots.
There is special touchup coating (never tried it myself, but looks like it gets good reviews, and the price is right)
Amazon com Rerack Dishwasher Rack Repair White 630076 Home Improvement
Or prong covers if you just have rust or damage on the tips (I've used ones like these, the long ones stay on good)
Amazon com Home Dishwasher Prong Caps Set of 20 Kitchen Dining
Oct 20, 2017 | KitchenAid Dishwashers
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Dishwashers Logo
685 people viewed this question
Top Dishwashers Experts
