Question about Kenmore Dryers
My dryer is a Kenmore model 110.64202200 and it will not spin, the belt popped. I am trying to put the new belt back on and need guidance.
  • Kenmore Master
  • 2,248 Answers
Unplug the dryer,remove the lint filter and remove the two phillips screws in front of the filter hole.with a screw driver pop the top lid,stick the screw driver in the top crack where the panels meet around two inches from each end and push down on the screw driver on both sides and the top will come up,next you'll see on the right side a wire connector,stick a thin screw driver in between the plastic on both sides to pread it apart so you can separate it,that's the door switch coneector,then on the right and left side around thrre inches down you'll see a 5/16 inch screw on both sides,remove them and then tilt the front panel out just a little and then pull up on either the right side then the left side and remove the front panel,pull the drum out,while you're in there vac out the dryer,next check the belt pulley,if it's the original metal pulley change it out to the pulley with a wheel on it,you can buy a kit that has the new pulley ,belt and rollers all together,i forget the part number but you can call your parts store and ask them for the kit and they will hook you up,the ribs on the belt touch the drum and the smoth side is up,put the pulley in the hole in the floor right under the motor pulley,if there are two sets of holes put it in the holes that are right under the motor pulley,next stick the drum back in and spin it and make sure the felt on the back is behind the drum,when you spin the drum tilt it down a little and the felt will line up on it's own,next make sure the pulley stayed in the holes,stick your head in the drum and hold it in place with your right shoulder,grab the belt and pinch it together with your left hand and pull it under the wheel of the pulley and rap the end of the belt around the motor shaft and that's it,after you get the front together you should pull the back wall off and clean out the duct that the lint filter slides into,four screws hold the duct on in the back and the two screws on top have to be out to remove the duct,then if the vent line is a long run from the back of the dryer to the outside duct go outside,make sure the outside vent is clear,remove the vent line from the back of the dryer and blow it out with a leaf blower,if you clean the dryer like this every two years you'll almost never has problems with this dryer.let me know how you make out
Posted on Oct 05, 2010
  • Sal DeAngelo Oct 05, 2010
    the part number for that kit with the belt,rollers and pulley is 4392065
    and it's around 35 bucks on the sears site
How to replace belt in 700 series
first step unplug the dryer.then pop the top of the dryer open by pulling it towards you and up,sometimes you have to pry it open with a flathead screw driver then remove the front of the dryer by removing the two quarter inch screws on the inside top of the front. then unplug the door switch it will be two wires attached to it.then pick up on the fron and remove.next remove the drumand place the new belt around the drum and install.then you will have to put the belt rubber side inwards on the motor pulley and the outside(non rubber)part of the belt needs to ride on the tensioner pully (little plastic wheel)spin drum clockwise to make sure tou have it alighned properly if it pops off try again untill you get it rite.Then reassemble and test.
Mar 02, 2013 | Kenmore 700 6972 Dryer
Good Morning: I have an older Kenmore Dryer with the serial # of : 77982600 and the belt broke. I can get the new belt but am wondering how it goes on. Do I have to remove the felt belt on the backside?...
dont mess with the felt on the drum... pop the top of the dryer. 2 clips hold it down.. use a screw driver to pop it. then take out screws on the front and bottom to remove the front part of dryer with the door . now put the belt around the drum put front on. then comes the fun part feeding the belt through pully tensioner good luck remove back to get to belt pully /tensioner
Aug 16, 2010 | Kenmore Dryers
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
May 28, 2009 | Kenmore Dryers
I need Directions how to replace the belt.
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......
May 04, 2009 | Dryers
Kenmore dryer hums/heats up, but drum does not spin!
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Yank out the tub. Clean the junk out (send me the coinery) oil the wheels and Idler with temp resistant zoomoil from ace hardware. Use this guide to replace dat belt Kimosabe:
BELT CONFIG 101
Apr 08, 2009 | Dryers
Won't spin
the belt is thru the frount.asuming there is noise when you start the dryer and its not turning,yes belt.if wont start at all other things to check first starting with door switch.check with me if need more help.ps if wanting in thru frount.pop top and remove frount door pannels.God bless ,tom
Jan 06, 2009 | Kenmore 73952 Gas Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Putting Belt back on Kenmore Dryer 63942
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the drum out, clean out the dryer witha vacuum and use this belt routing pic for reference:
CLICK HERE
Dec 23, 2008 | Kenmore 63942 Dryer
Electric Dryer (Kenmore) It Doesn't spin
The motor has to start to close a switch to let it heat so it sounds like you need a new belt.
Apr 24, 2008 | Kenmore 62602 Electric Dryer
Motor runs, but no spin on Kenmore front load dryer
more than likely your belt has come off there is a panel in back remove it and look inside now the wheel that keeps the belt tight has a habit of coming off if some yahoo didn't put it on right find it and look for two slots in the floor of the drier it slips into put it in the slots and pull it down then put the belt on top of it should fix the problem
Jan 01, 2008 | Kenmore 62802 Electric Dryer
Dryers Logo
403 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
