Question about Toshiba 19LV505 DVD Player
My 19Lv505 TV has stopped playing DVDs properly. I put a disk in, but nothing happened. Screen did not show a DVD had been inserted as it usually does. Disk would neither play or eject, not even when using controls on the TV. Now it is stuck in the slot. What to do?
  • 4,889 Answers
From what you have described it sounds like a problem with the eject/ loadmechanism. The DVD is lowered onto the lens-laser assembly that will cause the unit to read the disc. Due to the faulty mechanism it is neither lowering it onto the lens there by not reading the disc, nor ejecting. You can force the DVD player to eject by inserting a pin into the emergency eject hole(look) for a small hole at the front) and twisting it while repeatedly pressing the eject button. That should help you eject it. As for the drive. It needs to be replaced as this cannot be repaired.
Posted on Oct 05, 2010
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dec 27, 2014 | Digihome LCD TV
My computer wont read any cd's or dvds... I open the tray, everything works it has power to it and I can hear the cd spin inside as it trys to load then it stops and nothing happens on screen. If I put the...
It's a common problem if the cd\dvd rom is very used. Try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush".
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 13, 2010 | Alienware PC Systems Alienware Aurora High...
The tv works but the dvds wont play. The symbol showing the disk is trying to read appears and stays on screen but nothing ever happens. When I try to eject the disc it won't. I have to turn it off and on...
my dvd player doesn't play all types of discs, especially homemade like ones ripped from a home computer. However, i do not play many dvds, yet i have replaced the players many times. I dont think that most dvd players are built to last. Sounds like you have 1 built-in (to tv). The players are cheap now-- your better off saving the headache and replacing it- The last one i bought was $30.00 on sale-get a cheap 1 cause i think they all have a short lifespan.
Aug 31, 2009 | Disney DTD1363-CAR 13" TV/DVD
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
Screen says loading and after a while, says disk error.Then eject
hi try first to insert a clean up CD, and test your DVD player with an original DVD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
Apr 12, 2009 | Televison & Video
Dvds won't play
Hello lik2travl, What i would suggest doing is making sure all connections are pluged in, sometimes they wiggle out of place. If this is not the case please write back and i would gladly help.
Please post what you do and how you did it I look forward to your posts
Nov 11, 2008 | Samsung DVD-P401 DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
Jan 07, 2007 | Philips DVD Micro Theater Shelf System...
Toshiba 19LV505 DVD Player Logo
176 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
