Question about Kenmore Washing Machines
Model Number: 41742052100 Brand: Sears Kenmore Age: 1 -5 years We bought this washer (Kenmore front loader) several years ago and it's had plenty of use... over the past few months, we've noticed it getting increasingly louder during the spin cycle.. this weekend, while doing laundry, it started putting black (grease?) stains on our clothes. . unfortunately, didn't notice until 2 or 3 loads had already been washed and dried. So, now the washer is not being used.. home warranty will not cover it, and we didn't pay for the warranty on the washing machine. Is this one of those deals where it would be a better idea to just replace the washer than to pay to have it repaired?
SOURCE: Whirlpool Washing Machine is going to explode(shakes and shimmies)
put your level on the machine Adjust the legs so when you push down on any corner there is no rocking - easy
Posted on Nov 07, 2007
Amigaman
  • 248 Answers
SOURCE: whirlpool calipso washer
If these are gray spots it may be fabric softener. Try running a few loads without and see what happens. Also check the seal around outside of inner tub bottom to make sure it still contacts tub all the way around. If it doesn't, you need to have a tech replace the nutator assembly and hte bottom plate. Based on past experience, may be better off replacing.
Posted on Nov 19, 2007
  • 958 Answers
SOURCE: Clear greasy stains appearing on clothes from brand new LG front loading washer
the grease i'm sure would be coming from the machine. look at the water solenoids, detergent dispenser, dispenser solenoids, everything with rubber hoses.
they do put a clear grease just to insert the hose easier in the plant. and if it was not removed during QC, then it would come out now as you uses it.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
MNTECH
  • 1543 Answers
SOURCE: washing machine stains clothes
You can pull the agitator straight up and off to check if there is any grease / oil on the bottom of it. You may have to use a belt or similar item to slip under the agitator and attach the other end to a broom handle to pull up if it is difficult to remove. If there is grease / oil, it is not very easy or inexpensive to repair. The average life of a washer is about 9 years, so this one doesn't owe you anything. I'd look into a new front load unit which uses much less water and spins clothes out at 2X or more the RPM's of your current machine. Please don't rate this solution as anything but a FixYa rating will lower my overall score. Thanks.
Posted on Nov 19, 2008
kram26
  • 544 Answers
SOURCE: front loading washer makes loud noise
HI,
may i know the model of your washing machine ?
if it is a kenmore you can check this suggestion.
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
A dozen or so loads shouldn't have caused any damage to the brake and drive tube assembly.
The basket drive block is about $20. You will need a spanner wrench to remove the span nut
that screws onto the basket drive block. They have one for about $20
If the brake and drive tube tabs are bent, your best bet would be to replace the brake and drive assembly. You can try gently bending them back with pliers, but I would hate for them to snap off completely. Be careful not to damage the seal in the process.
Depending on the severity of the bend in the tabs, you may not need to do anything to them. Make sure to line up the tabs to the slots on the new basket drive block and hammer in down completely until the tabs and slots are flush. Inspect to see if the bent edges of the tabs are bent inward further than the width of the basket drive block slots. If they're bent too far in, it may wear the new block out quickly and the same issue will come up.
When you re-install the spanner nut to the basket drive block make sure to tighten it hard (use the spanner wrench and a hammer/malet.)
You don't need to grease the shaft.
thanks,
Posted on Mar 20, 2009
How do i find the year of my sears washer
Your Kenmore is a Whirlpool.
Therefore, you need the serial number to determine the year. The second digit in the serial number is the year code.
You can find the lookup table here:
Determining the Age of Your Whirlpool Appliance
Oct 21, 2014 | Sears 4.5 cu. ft. Top-Load Washer
I need to buy the timer for the kenmore 24032 \ 24036
You can buy parts for Kenmore washers from Sears Parts Direct
You need the complete model number You can find it
Front Loader
Top Load
Washer-dryer combo
Jun 22, 2011 | Kenmore 24032\24036 Top Load Washer
Not a problem ... Just bought a Kenmore Elite HE3t washer & dryer and read bad evals on Sears.com.....are these good machines, or should I change my order?
I would send it back ASAP, had our Kenmore Elite front loaders for less than 2 years and it has been nothing but trouble, so far it has cost us $200.00 in repair fees and washer still not fixed, expecting another so called Sears expert out tomorrow that will be another $129.00 for just showing up without guaranteeing he will fix anything.i
Sep 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 417 44042400 Front Load machine Sears says does not exist
YOU ARE ABSOLUTELY RIGHT. THE COMPANY SHOULD HAVE KNOWN ABOUT THIS. HERE IS MY SOLUTION: GO TO LOWE'S HARDWARE AND BUY A WASHER AND DRYER THERE. BUY THE GE BRAND. 3 YEARS AGO, WHEN OUR MAYTAG WASHER DIED, WE BOUGHT A NEW GE WASHER BEFORE MY FATHER DIED IN 2006. BUT CHECK INTO THAT. MY E MAIL ADRESS IS CoolRod41@yahoo.com IF YOU FIND THIS IMFO HELPFUL. GOOD LUCK.
RODNEY
May 17, 2009 | Kenmore 43042 Front Load Washer
Sears Kenmore Front Load Washer model number 41742052100
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 07, 2009 | Kenmore Washing Machines
Trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite Top Loader (Model 110.16982500), 2.5 years old leaves white sheets with black dots and 1/2 inch black lines in varied places.  Does this for days and then not at all for several weeks. Using...
Try using the juice from a fresh lemon to clean the machine internally, where your washing sits. Preferably wipe the lemon on the surfaces that are contaminated.
Apr 04, 2017 | Washing Machines
Kenmore washing machine shakes when spinning out
our's did this, it shook horribly. it turns out one (or more) of the shocks had come out and the technician had to come out and replace the shocks.
Nov 03, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
91 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
