Question about Lasko 5365 Ceramic Compact Heater
Heater shows red ready button, but won't turn on. Any ideas? I've already unplugged, tried multiple outlets and vacuumed the heating elements.... ???? What next ????
    Problem Solver:
  • 5 Answers
Turn temperature setting all the way up.
If that does not fix, turn temperature setting all the way down, turn heater off, unplug for at least 10 minutes.
Posted on Dec 08, 2010
My tv is not getting any power no lights turn on
try your tv in another part of the house and if it dos not work then the internal fuse may be gone
Feb 18, 2014 | Element Electronics Televison & Video
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
Steady Yellow Light
Is it an old model? Should you try to have it replaced?
May 18, 2017 | Holmes Products BH3955-U Bionaire Utility...
Hi Sir my heatbgun is still starting but the problem is its air takes time to heat even if i turn its heat control to the max . What could be its problem?
Usually you should have heat very quickly. I can think of a few things that might cause low heat. One would be a low power level at the outlet. The other might be the heater element is just about worn out. And third is the power or heat selector switch is faulty.
I've seen the low heat from low power caused by too long extension cords as well as low power levels. Try plugging into a different outlet and directly and see if it heats up normally.
Unfortunately if it is a problem with the heater element or the switch unless you are under warranty you would have to buy a new unit. If you have warranty then you should contact the store you purchased or McCulloch about getting it replaced.
Sep 02, 2011 | McCulloch Heat Gun Kit
Autofry Mti-5 - no error codes, was working fine and suddenly won't heat up at all.
we have a MTI-5 Autofry, and the display shows "Basket Can't Find Home". what can you recomend?
Jul 31, 2011 | Kitchen Appliances - Others
Saunacore 44QRS, is a 120 vac unit. As soon as you turn the elements on it trips the circuit breaker. I've tried plugging into different outlets, even a dedicated 20 amp circuit. The unit is only...
must be running with gfi. run for one hour without neutral wire connected. it will dry moisture content within heater elements. then reconnect neutral wire, and walla, no tripping.
Jul 13, 2011 | Saunacore Standard Residential Sauna...
Suddenly stopped heating water
Check the top thermostat2_bing.gif... right above it is a red button that you will have push hard on to reset...
If all that checks out then you have a bad top element...replace that...
heatman101
Apr 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Nov 14, 2008 | Heating & Cooling
Honeywell Compact Quick Heat Ceramic heater with tilt feature - HZ 325
Your prob is their is a thermostatic solinode that is trigger the unit to go off--because it thinks itself as too hot and unsafe to be on--this trigger was defective or damaged by disuse and/or fatigue------give it a shake-- better yet, when cool and unplugged-vacuum or blow out with compressed air-with out disturbing integrity of workmanship on device--if that no worky--time for new one---thermostatic element is dirty, device being of differing Mghz than outlet, if fairly new device--amperage of outlet is too small for device to work properly. If it is a 240 volt or a 120 volt device and your attempiting to use the wrong voltage outlet--STOP USING THE DEVICE
Jan 21, 2008 | Honeywell HZ-325 KAZ Ceramic Compact...
Lasko 5365 Ceramic Compact Heater Logo
577 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
