Question about Cell Phones
After I deleted the factory web sites from my i6 pro It shut down and I can not turn it back on...After going holding the power button down the screen shows CPS for a second then powers back off. Any help is much appreciated
  • William Ward Oct 05, 2010
    Thank you for your post:
    Yes the battery is fully charged. This phone is a i6 pro from china that I ordered for cellphoneshop.com
    I have tried all the troubleshooting steps you have posted and It still will not power back on.
    It was working find until I deleted (china mobile) from the network settings. As soon as I deleted this web address it turned off and I've been unable to turn it back on since. I have searched for technical manual on this cell phone with no luck.
    Thanks for your help
    William
    Thanks for all your help!
  • 567 Answers
Please ensure that the battery of the phone is charged fully.
Deleting some websites from the bookmarks should not create an issue. Is this what you meant by saying "I deleted the factory web sites?"
What all was deleted?
Please try the following steps:
1. Remove the memory card and SIM card (s).
2. Remove the battery.
3. After about 1 minute, please insert the battery (Fully Charged)
4. Try to start the phone with the SIM and memory card not installed.
5. Insert SIM and attempt to start.
6. Insert Memory card and attempt to start.
In case it starts without the card, just format the card and it should work for you.
In most issues like these the Memory Card is the cause of the error.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
Posted on Oct 05, 2010
  • Anuj Joshi
    Anuj Joshi Oct 05, 2010
    I understand that you deleted (China Mobile) from the network settings.
    Well, since it has not worked after all the steps it looks like you will have to get it serviced.
    The phone is missing some critical files it needs for running.
    There are techs who might help you by flashing the phone's entire memory and refreshing the Operating System.
    This procedure requires the phone to be hardwired to a box and the internal memory is rebuilt.
  • Anuj Joshi
    You are most welcome William!
How do i do a hardfactory reset? on my zte pro max?
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
Sep 24, 2017 | ZTE Cell Phones
I forgot password and now I cant access my tablet.
Here are some options which came from the trio tablet website: What do do if forgot my password to unlock to my tablet
Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
  2. Tap on Backup and Reset on the left hand column.
  3. Tap on Factory Data Reset on right hand side.
  4. Tap on Erase SD Card. (optional)
  5. Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset
  6. Tap Power button to select.
  7. Use Volume - button to scroll to Yes.
  8. Tap Power button to select.
  9. Tap Power button to select Reboot System Now.
This site also had some tips: Different Hard reset factory wipe methods for Android Tablet
Mar 21, 2016 | Audio Players & Recorders
Stuck on shutting down screen
If you press and hold the power button for up to 15seconds that should close it down.
Mar 14, 2015 | Sony VAIO Pro 11 Ultrabook
Why am I unable to unlock my Zepad so I can remove photo on screen?
You have to format your device by Hard reset keys directly.
Procedure is very simple.
1.Turn off your Tablet PC by pressing Power Button.
2. Press/Long Holding Volume Down Button OR Volume UP Button.
3. Then Press Power Button to Turn on device
after that you will see factory resetting menu just select factory reset the pres Enter Or Yes.
Thanks
Nov 27, 2017 | Tablets & eReaders
How do i unfreeze my tablet
Hold down power button until shuts off. If freezing continues then has a virus. Go to app store and download avast and do a full system scan. If can't do that then do a factory reset. Back up everything on computer first. Hold down home button, power button and volume down at the same time when powered off. After boot screen release only the power button. When a screen loads use volume keys to navigate to factory restore and press power button then wait till done. If volume down doesn't work then use volume up instead.
Jul 24, 2014 | Visual Land ME-107-8GB-WHT Tablet Computer...
2004 chevy suburban wont shift into first gear starts in second
Hard reset will bring your device back to factory settings thus it will delete all your personal files so a back up copy is recommended.
You need also to charge your device not less than eighty percent.
Press and Hold power and volume buttons at the same time until your tablet turns ON and see the android logo. Once it turns ON release all the buttons then use the volume key to scroll then power key to select. Scroll then select wipe data/factory reset.Scroll then select yes--delete all user data. Select reboot system now and wait until it finished and restart.
Apr 28, 2014 | 1997 Chevrolet Suburban
What does it mean when android robot is laying on its back
I am giving you an example with an Motorola Tablet. I'd try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
As you're going through the options don't do the factory data reset, look for wipe cache partition then follow the instructions to reboot.
Hope this helps!!! Let me know if you need more help
-Nadeem
Dec 25, 2012 | Ematic 7" eglide Pro Tablet
Too many pattern attemps on motorola xoom
hi ,
try to hard reset your phone to back it in its original factory setrting...
  1. With the device powered off, press the Power button to power the device on.
  2. When the Motorola logo appears press and hold the volume down key.
  3. When the Android recovery text appears (in the upper left), release the Volume down key then press the Volume up key.
  4. When the Android recovery screen (Android with exclamation point in a yellow triangle) appears, press and hold the Power button.
  5. While holding the Power button, press the Volume up key.
  6. Press the Volume down key to select wipe date / factory reset.
  7. Press the Power button.
  8. Press the Volume down key to select Yes -- delete all user data.
  9. Press the Power button.
  10. Ensure reboot system now is selected then press the Power button.
Sep 28, 2012 | HTC Touch Pro Smartphone
No power at all
You may need to perform a SMC reset on your Macbook Pro.
Directions for doing a SMC reset are available on the Apple Web site (Click Here).
The part that is of most interest on this web page is:
  • Shut down the computer.
  • Disconnect the MagSafe power adapter from the computer, if it's connected.
  • Remove the battery.
  • Press and hold the power button for 5 seconds.
  • Release the power button.
  • Reconnect the battery and MagSafe power adapter.
  • Press the power button to turn on the computer.
  • Dec 30, 2010 | Apple MacBook Pro Notebook
    How do I Restore my Lenovo Y550 back to Defaults.
    beside your power button there is a small button that will have a curved arrow on it, your system must be shut down then press and hold down the button wth a curved arrow or it may say NOVO on it press and hold it down for 4-5 seconds while the ssytem is shut down the computer will power on if you press that button then it will look like it is loading windows but it will show on the screen Lenovo Rescue OneKey System then you might see the option fix files or advance if this screen comes up it means that you still have the option to get windows working again if you click advance it will give you an option of Lenovo Password Management, Lenovo Anti Virus and Lenovo Rescue System select lenovo rescue system it will give you the options restore from initial backup, restore from customer backup select restore from initial back up to restore back to factory defaults unleass you created a back up of your own ^_^
    Jun 12, 2010 | Lenovo 3000 Y410 Notebook
    Cell Phones Logo
    105 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
