Question about Seiko Melodies in Motion Clock
My clock still keeps time, but no motion nor music? I pushed the reset button and it lights up but nothing happens. What's up?
I have a Seiko musical motion clock that I bought in Japan a few years ago. For setting the time it has a "A" and "B" button that you hold down? I dont have the instructions to set the time. It says "Radio Controlled" but the time was always manually set before by luck trial and error. How do you set the time?
Posted on Apr 04, 2011
  • 831 Answers
Thank you for contacting FixYa.
Please check the following link from Seiko clocks:
http://www.seikoclocks.com/#FAQ
Best regards. Jewel
Posted on Oct 05, 2010
I recently moved my melodies in motion clock back one hour for daylight savings time and now the clock is not keeping time. I suppose I should not have moved it backwards but now what do I do to get the...
By moving the clock back one hour you changed from DST to standard time, not as you stated. Some clocks require you to rotate the hands clockwise to set the time back. Your clock may have been damaged beyond repair.
Nov 05, 2013 | Seiko Melodies in Motion Clock
Ive just moved into a flat with a servis 7kg 1500AA washing machine and i have no instructions for it. when i press the on button the yellow light above another symbol flashes and nothing happens. ive...
Hi. Set the dial to reset (12 o-clock position) then push button second from right. Now set to program required and press button again. Should work now. Needs resetting every time, this is normal. Hope it works for you.
Sep 10, 2010 | Washing Machines
I have an Armitron Musical Quartz watch. Before, the watched "played" but did not keep time. I replaced both batteries and now the watch keeps time but doesn't "play." HELP!
If you go to the Amitron web site (amitron.com) and select "support", you will arrive at their list of instructions.
Choose the one that matches your watch, download it and follow instructions.
Jan 03, 2010 | Seiko Melodies in Motion Clock
How do you reset the clock
Turn on the lights in your room and it will be obvious. On the Bose Wave Music System clock radio remote there is a + and - button labeled "time." This is how you set the time. Hold either the + button to move the time forward or the - button to set the time backwards. You don't need to push any buttons before you press the + or -. After you have set the time you can press the "alarm time" button to lock in your changed time.
The standard remote does not have a back-light feature. However, if you bought the optional larger remote and try to set the clock in the dark with the back-lit buttons, you won't be able to see the word "time" above the + and - buttons. This is because the word "time" is written on the metal part of the remote, which does not illuminate with the back-lighting feature.
Nov 01, 2009 | Bose Wave music system large Remote...
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 | Ovens
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Seiko Melodies in Motion Clock Logo
1,236 people viewed this question
Top Seiko Home Experts
Jimmy Accardi
Jerry Greenberg
Jerry Greenberg
Are you a Seiko Home Expert? Answer questions, earn points and help others
