Question about Coby MP-C741 MP3 Player
Playlist on MP3 player
I just bought my first MP3 player. With WMP on XP/SP2 I can rip a CD to MP3, create a playlist, drag/drop the list to synclist & sync to the player.
Problem is the files are not part of a playlist on the player, they are just multiple files. The player says there are no lists.
I want to rip/sync multiple CDs each into its own list. That is possible, right ?
Thanks
  • mungo_sd Jun 04, 2008
    there does not appear to be a way to copy folders to this model Coby. The manual does not discuss it and the player itself does nto have a folder option.
    Problem Solver:
  • 12 Answers
I would not use the sync. I would make a new folder for your choices and put them in the order you want to hear them. Name the folders according to country, hip-hop, rap etc. If you want put the cd into it's own folder. Name the folder the cds shortened name...
Posted on Jun 02, 2008
How do I load my music cd's into my computer then download them to my new polaroid MP3 player
Windows media player will do it automatically.
If not :
Place a cd into the try and close it.
Open WMP.
Open the CD in WMP.
Select all songs, and click the RIP tab.
They should, by default, go to "My Music" folder in a folder named after the CD your ripping.
When you attach your MP3 player,
Autorun will ask what do you want to do?
say open a folder to view files, or let WMP sync up to it.
You can manually drag and drop your files to the MP3 player.
PLEASE RATE THIS ANSWER.
Aug 30, 2011 | Audio Players & Recorders
How do you download music to an mp3 player from a cd?
Normal audio CD tracks should be converted to mp3 files onto the computer's hard drive, first.
This is called ripping or RIP function.
There are several programs that can RIP audio CD.
It is important to convert music into the correct bitrate for the player to match for playback. (192 kbps is good quality and often used)
You can use Windows Media Player 10 or 11 for conversion.
When you use WMP 10 or 11 and the player is detected in the program:
1. Tell the player were your music library is: setup your music library.
2. Create a playlist; make playlist name and add mp3 files to the list.
3. Synchronize the playlist with mp3 files to the player.
If the player cannot be detected in WMP 10 or 11, but only can be viewed as a removable disk in "My Computer" : use the "copy and paste" or "drag and drop" method to put mp3 files from the computer onto the player.
When needing more help, don't hesitate to write a comment in this reply.
May 01, 2010 | Coby MP-C653 MP3 Player
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
How do I create playlists?
The manual, etc is available at www.p4c.philips.com
You will have to, unfortunately, set up your Windows Media Player for Auto-Sync (has definite drawbacks - inclduing: adding songs, pictures, etc that you DON'T want into the GoGear). Playlists can only be synchronized to your player via “auto sync”. Autosync will automatically synchronize your Windows Media Player library content and your player content each time you connect your Player to the PC. If you use the “manual” sync option the tracks in the playlist will transfer to your player but the playlist itself will not.
Nov 23, 2008 | Philips SA5125/37 MP3 Player
Cannot Copy Music
u want to convert the song into mp3format using real player.
Sep 18, 2008 | SanDisk Sansa m250 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Putting music in different folders
Within WMP 10 create a few playlists and drag/drop music files to the appropriate playlist (drag whole albums or individual songs). When you have constructed and filled your playlist(s) connect your player, open the sync tab, and drag the playlist(s) to the sync box. Click sync and smile. ;)
Jan 12, 2008 | Creative Labs Muvo V100 MP3 Player
How to download music to this mp3 player
You can either use Windows Media Player 10 or seek out the Creative software for this model at the Creative.com site. With WMP 10 I'd suggest you create some playlists and the drag/drop to said playlist the open sync and drag drop the playlist you wish to load. Bada bing bada boom...
Jan 03, 2008 | Creative Labs Muvo V100 MP3 Player
Cannot create playlist
You must be in MTP mode, create a sync list in WMP, then drag the play list to the sync list of the e-280. it will create the new playlist on the e280.
Dec 07, 2007 | SanDisk Sansa E280 MP3 Player
Coby MP-C741 MP3 Player Logo
134 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
