Question about Bosch Skil No.4280 - 01Variable Speed Jig Saw 3.5A
It's actually a Skil model 4280 sabre saw. Problem is it doesn't grip blades properly, so they are constantly slipping out. Chuck seems to be engaged, have shot WD-40 in it - no change. Ideas?
There is nothing wrong with your Skil 4280. The universal U chuck blade is the problem. Look at Lenox blade 4318JC or Disston 5418 and you will see a slight ridge on the face of the blade on both sides where the teeth start and the blade tail engages the chuck. Without the ridge the blade will come out.
Posted on Nov 10, 2010
How do you change a blade on a Skil 4280 jig saw?
It is REALLY easy, when you know how. There is a black piece, the larger one, near blade insert...lift it and VOILA, you can insert or remove blade easily. I lost manual and spent forever trying to put blade in. Hope this helps.
Sep 22, 2013 | Skil 4280-01 4280 Variable Speed Jigsaw...
The drill chuck is locked and not shifting forward or reverse
Check that there is not a reverse screw in the bottom of the chuck which has become loose. This can jam the chuck, screw it in (anti clockwise) or Spray inside with WD40, then use a large pair of grips to free it in both directions.
May 12, 2012 | Skil 6237-04 3/8 Corded Drill/ Driver
How to change blades
unplug it. remove the bolt in the center of the blade. the blade will slip off then. a wrench for this should have come with your saw. if not, use any properly sized wrench. if needed, pull back the blade guard, put the blade on a old piece of wood, push down on the saw and use the wrench. the wood and your pressure will stop the blade from turning as you loosen the bolt
Feb 12, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Pin and lock where the blade is come off and giving me a hard time putting it back
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Aug 15, 2010 | Skil 9.5 Amp Orbital Reciprocating Saw...
How do i change the blade in a reciprocating saw?
heatman101
Aug 05, 2010 | Skil FactoryReconditioned 920501RT 85 amp...
Blade shaft slipping
It could be a number of issues. These saws have a built in vari-torque clutch used to prevent kickbacks. Basically, when the blade binds while cutting, the arbor spins but the blade won't (prevents kick-back). It works by not over tightening the blade washer (this is the slip clutch), if you over tighten, the blade washer can't prevent kick-backs because it has no room to slip, if you under tighten, the arbor spins, but the blade won't. I'd try to tighten the blade washer 1/8 turn and see what that does. If your actual arbor shaft is not spinning, you could have a gear issue. If you hear the motor running and the arbor slips (not the slip clutch) sounds like there might be a gear issue,If the rotor is spinning (the part inside the stator-i.e. the electric motor section) but it is not transfering that movement to the arbor, it has to be a gear issue.
Jun 07, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Motor goes round in the dewalt but there is no drive.
check bearing and brushes, this was my problem on my SKIL 4280.
Mar 28, 2010 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skil saw motor runs but blade won't spin
you have a loose nut.  Let me explain...the nut and washer that holds the blade to the motor has worked loose.  You need to remove the plate around the blade to acess it and on the end of the blade is a large nut.  Tighten it with the power off.  Sometime there is a grove on the motor shaft to hold the motor or sometimes you need to put a screwdriver into the teeth of the blade to hold in place to tighten.
Apr 04, 2009 | Skil 10" Table Saw
Bosch Skil No.4280 - 01Variable Speed Jig Saw 3.5A Logo
510 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
