Question about Sony Cyber-shot DSC-W55 Digital Camera
Memory card assistance
I put my 4gb memory card in the camera and it doesn't appear to be accepting it. the camera lets me take a couple of pictures and then says the memory is full. ideas? i install the drivers that were on the disc.
    Champion:
  • 203 Answers
I don't know what year or model camera but 4 gb basically only work in 2 yrs or newer models-not all cameras support card due to diferent file format on sdhc cards-try going back to 1 or 2 gb and play it safe if they work
Posted on May 28, 2008
I put in an SD card and it only records to the memory. How do I get it to record to the SD?
Hi Nancy,
I have a couple of generic suggestions. First, make sure the SD card lock tab is in the "unlock" position. When in the lock (or sometimes called "write protect") position, it will not accept data to be saved.
Secondly, check to make sure that the card is a type that is compatible with your camera. If you camera specs an SD card, install and SD card. If it requests and SDHC card, provide and SDHC, and so on. There have been several versions of cards that all LOOK the same: SDSC, SDHC & SDXC. The "SDSC" (Secure Digital Stand Capacity - at introduction was called simply "SD" as it was the only capacity) type has a capacity of 4GB or less. The first devices could not access areas memory in the 4GB + range. Next came the "SDHC" (High Capacity) card. These cards were originally set for 4GB capacity and greater. As the older SD devices faded away, the low end capacity of SDHC cards dropped from 4GB to 1GB or smaller. The SDXC card (eXtended Capacity) and SDIO (Input/Ouput) will supersede the SDHC types as time advances.
Lastly, do not use card types (or those with greater capacities) that do not appear in a compatibility chart for the camera (or any device for that matter). When trouble arises, use only recommended hardware (memory cards) as shown in manuals or online info.
Sep 25, 2013 | Panasonic Sdr-t70 Camcoder,78x Zoom,64gb...
Memory card size
i think those photos save in your camera built in memory. took the card out and turn on the camera . NOw press the play button and see the photos appeared in screen or not. If yes then you have to make the default storage location as your memory card.
Aug 07, 2012 | Nikon Coolpix 2000 Digital Camera
While taking pictures my camera all of a sudden froze and said card error, tried putting memory card on computer but it won't read it have tried using recovery programs but it freezes them please help
If your memory card is 4GB or larger, AND if your computer is two or more years old, your computer's card reader might not be able to read the newer 4GB SDHC card. In that case, just purchase an inexpensive USB card reader from WMart, or Amazon (here's an example). Try a different card reader first to see if you can directly copy and paste the pictures from the card onto your hard drive. If the new card reader doesn't see the files, then try recovery software. Here's some freeware to try. If the software still doesn't see the card with the new card reader, you may next need to try the corrupted card procedures described at the bottom of this linked article.
Nov 26, 2011 | PNY 4GB Secure Digital High Capacity...
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
I was taking a picture and my camera suddenly got slow and turned off. when i tried to turn it back on i had to try a couple of times to actually get it working, then it said that "this card cannot be...
Your memory card is damaged. Please try to get back your pictures at camera shop. But usually, nothing can done on defective memory card. I suggest you to back your memory card files on your computer next time to prevent this problem.
Regards, Jay
Jul 28, 2010 | PNY 4GB Secure Digital High Capacity...
4 GB memory card = 6 pictures
See the camera specifications, whether it supports memory cards above 2gb, if it supports it must have the "sdhc logo", most of the old camera's dos'nt have support for memory cards of capacity 4gb and above.
Jun 17, 2010 | Polaroid A500 Digital Camera
Scandisk memory card keeps saying error
Some cameras will not work with the larger flash cards. Also the SDHC requires an adapter that accepts the high density. Many built into the computers do not accept the high density and will demand they be formatted. Verify the requirements of the devices you have for compatibility.
Apr 27, 2010 | SanDisk 4GB microSDHC Memory Card
Put 4GB card in - OUT OF MEMORY appears.
I have nikon coolpix L5, i just brought a 4gb memory card that's supposed to be compatible, but when i go to take a picture it say You cannot use this card?
Jul 11, 2009 | Nikon Coolpix 5700 Digital Camera
D50 cannot use a 4gb card??? I use 1gb, 2 gb and no issues, now bought a 4gb card and get a CHA indicator on camera and will not shoot pictures. Can this camera be programed to accept a 4gb or larger...
No, the D50 will not (as you've discovered) accept an SDHC memory card (anything bigger than 2gb is SDHC). I haven't found a firmware upgrade for the D50 to rectify this issue, either. I own a D50 also, and love it, but bigger cards would be nice.
Jul 09, 2009 | Nikon D50 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
52 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
