How do I partition a 64GB USB flash Drive into two 32Gb drives with Windows XP SP3?
  • 7,733 Answers
With this fee app --->MiniTool .
Posted on Oct 05, 2010
Pny Attache 64gb flash drive will not format correctly
You can go to Administrative Tools>Computer Management>Disk Management and try to format it from there. You may need to delete the partition that is on there and create a new one. If you are still unable to format the drive correctly, contact the manufacturer and request a replacement.
Mar 14, 2014 | PNY Attache 64GB USB Flash Drive
So So Happy USB flash drive won't install onto windows xp
Format the flash drive without using the executable installation program on the flash drive.
Insert new flash drive, do not let anything auto-run. View the drive in the file explorer. Right click on the drive and choose Format in XP to let XP do a full format (not a quick format) of the drive. This will ensure that the drive works on XP... it will then also be accessible on a newer system.
XP may also not be able to work with flash drives over 32GB, or will only give you access to the first 16 or 32GB.
Sep 05, 2017 | Computers & Internet
Installed win 7 but want restore to xp
To reinstall win XP from usb flash drive you need WIndows XP cd, 1 gb flash drive and Novicorp WinToFlash. Download WinToFlash to your computer and follow instructions to transfer Windows XP from cd to flash drive, After that boot your notebook from usb device and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon" then install win xp normally, but format C partition. After first start of your notebook boot again from flash drive in "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon". Now windows is starting, go to start/my computer right click on it and go to properties in this windows go to advanced tab and there go to startup and recovery, click on settings, in new window go to edit tab and in new window change the line "multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP" /noexecute=optin /fastdetect" after windows XP write the type of your XP Professional, Home Edition, or Media Center. Now you can remove usb flash drive and boot normally from hdd.
Nov 12, 2012 | Advent 4211c Notebook
How do I make RAID 1 HDD's appear on Bootable USB WinXP Install?
a waste of time and effort installing win xp on anything as it is no longer supported by Microsoft and had real problems with drivers for just about everything
install win 10 and it will work
Feb 28, 2018 | Dell POWEREDGE 1950 Server
Hello.. i was using windows 7 for a while and decided to go to xp because of gaming...though windows 7 has directx 11 but i think games perform better in xp..my cd/dvd rom does not support cd's so have to...
Did you create a drive image prior to the install ?
If so go back and run the Games from Windows 7 in XP Compatibility mode.
If not use Symantec Partition Magic to create two partitions and operate a dual boot system where you use Windows 7 for most things like the internet and Windows XP for games I also suggest that you use GameXP to optimize XP for Gaming
May 14, 2010 | Microsoft Windows XP Professional SP3 Full...
Formatting pen drive 64gb
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format pen drive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jun 22, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Unable to format 64 gb kingston pen drive
These are actually ccore flash drives, shipped with the name "Kingston". YOU CAN FORMAT ANY ZIP DRIVE WITH "HP USB DISK STORAGE FORMAT TOOL". Trust me, it really does the needful. I had the same problem earlier =)
Feb 12, 2009 | Computers & Internet
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Computers & Internet Logo
332 people viewed this question
David Payne
David Payne
