Question about Toshiba Sony XRCA350X
I am replacing a very old Toshiba cassette/radio and it has only one wire (+) going to the speakers. How does that work? I am trying to install another radio that doesn't work this way.
  • 979 Answers
Hello sir, hi most likely the one wire is the live audio out, you are missing the ground line, the missing wire maybe connected to ground already, just like in car wiring where the other line is the body. if not check your speaker connections, they should have a "+" and a "-" sign terminal. to complete a speaker connection it should have two terminals. No speaker would work with only 1 terminal.
Posted on Oct 05, 2010
I have just bought a boat which has a alpine 7618r fitted but its not working can i slide a moden cd/mp3/usb replacement unit in there using existing wiring /speaker loom
Yes you can replace that unit however the harness that plugs into the old alpine in all probability will not work with another radio so you will have to connect the new radio's wiring harness to the boat's harness.
Aug 17, 2016 | Alpine 7618r Audiophile Car Headunit Tape...
I am changing out a Clarion ARX7570z to NZ500. Have most of the bugs worked out but I need a wiring diagram for the ARX to figure out the which wires are which. HELP!
the wiring diagram is out dated for the cassett player ....
here is what i know
red is ignition swichted
yellow is contstant power
black is ground
blue power antenna
blue with white strip amp turn on
gray + f right speaker
gray/black strip - f right speaker
white is + L front speaker
white with black strip is - L front speaker
green is + L rear speaker
green with black strip - L rear speaker
purple is + r rear speaker
purple with black strip - r rear speaker
your orange with white strip is illumanation not used
100% of all aftermarket radios are color code this way if you have install diagram for new radio it will be the same as old clarion radio ..
but make sure u have a digital volt meter to check power on red and yellow wire and comming from the factory harness be for you connect new radio just to make sure it does have powers and check other wire for power also just so you dont blow up new radio ... you can blow up a radio by connecting a wrong wire faster than you can blink your eyes ..... if you need a wire diagram for you modle car email me with it a http://www.tintingbyfredjohnson.com and go to contact and send email
Dec 28, 2010 | Clarion ARX7570z
Changed Radio - now speakers don't work. I took out the Chrysler radio that had a CD and cassette in it and replaced it with an aftermarket radio. Now the speakers don't work. I got the adapter from a...
Sounds like your Gr Caravan has the premium sound package. You likely haven't hurt anything - but you may need to modify the wiring a bit. The speakers have a tweeter speaker in the center of the main speaker and the wiring goes through that. However, it only worked with the premium package. Go in to the speakers and move the wiring connections from the tweeter to the main speaker. Your other option is to replace the speakers.
Jan 19, 2010 | 1994 Dodge Grand Caravan
Trying to install factory cd-cassette combo from a 1999 ford explorer into a 1996 ford crown victoria with only a cassette radio player. need to know wiring data on both vehicles.
Hi and welcome to FixYa,
On your need for the radio wiring of 99 Ford Explorer and a 96 Ford Crown Victoria, see below wiring scheme:
Confirm with a voltmeter on the +12 and an ohmmeter for speaker continuity.
Good luck and thank you for asking FixYa.
Oct 30, 2009 | Car Audio & Video
I have a 2001 Dodge Ram 1500 that I'm trying to up grade my radio form a A and fm cassette to a dual CD cassette . I need help with wiring because they are different colors.I have the new 16 pin harness...
2001 Dodge Ram 1500 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Sep 09, 2009 | Durabrand Car CD Player and AM/FM...
91 Ford Tempo - New stereo won't work ... Please HELP
here is the radio's wire color diagram, u should be able to fix the problem with this info.Fuse box is on drivers side under the dash.
1991 Ford Tempo Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Apr 12, 2009 | 1991 Ford Tempo 4 Door
Olds Cutlass factory radio/cassette, radio doesn't work.
When you say tried different radio and it didn't work, does this mean the tuner acts like it is functioning, but you hear nothing out of the speakers?
If so, this stinks of a bad ANTENNA...
Mar 05, 2009 | 1987 Oldsmobile Cutlass Supreme
JBL Pro Computer Speakers....
hi,
I believe your old sound card may be of higher quality than your new one, I had the same problem years ago what I did was this, I ran my speakers through an old dedicated dubbing cassette player out of an old kenwood stack stereo then into the computer, the cassette has a mild adjustable preamp when in record, you will have to put the deck on record the rest of the time with a blank tape- any old cassete deck will work.(thrift store) and your going to need a couple parts from radio shack. If you have the know how I suggest switching the audio cards out, drivers etc and / or seeing if you can have them both plugged in without an issue. If issue then try cassette then call and complain to the computer company for installing sub standard equipment.
computer audio output-> line in cassette->line out cassette-> line to speaker input
good luck
J
Jul 25, 2008 | JBL Media 2000 Computer Speakers
Car stereo installation speakers
Your old unit was a common ground unit meaning all speaker grounds as well a radio ground were the same. The new unit should NOT be connected to this wire configuration. Newer units change the potential difference of the speaker power meaning that the - wire of the unit may have negative 24v on it so IT CANNOT BE REFERENCED TO EARTH OR CHASSIS GROUND.
I would recommend rewiring the speakers to the radio for best reliability and sound quality.
Dec 31, 2007 | Jl Audio 12W3 Car Subwoofer
Car Audio & Video Logo
21 people viewed this question
Top Toshiba Car Audio & Video Experts
Philip Rowney
Philip Rowney
Jerry Umali
Are you a Toshiba Car Audio and Video Expert? Answer questions, earn points and help others
