Question about Kitchen Appliances - Others
Can't get lid off steam dream, any hints - Kitchen Appliances - Others
Won't turn on
Hi Sab, you need to replace the thermal fuse on the ascaso dream. Ascaso dream safety fuse
Mar 17, 2014 | Ascaso Dream Espresso Machine
Ascaso Dream
If your steam wand is leaking then you may need to replace steam wand o rings. These can be found at Ascaso gasket kit Dream Arc Basic . Available in a kit with easy to follow instructions.
Try Dream Arc Basic Ellipse 150 Products
Feb 16, 2014 | Ascaso Dream Espresso Machine
Lost manual for steam Dream platinum N2813
Haw much water goes in the steam dream platinum
Feb 10, 2014 | Vacuums
Ascaso dream wand wont heat or steam
You should descale the machine, as you may have a blockage in the steam tap.
When descaling make sure that the descaled water goes through the steam wand as well as the group. JURA descaling tablets
Mar 26, 2017 | Ascaso Dream Espresso Machine
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
Cant make hot milk or foam ascaso dream the wand doesnt work it just stopped. also my coffee is not hot, only lukewarm ive opened it up and everything looks ok, its all just electrics all of which look...
Hi Mike,
You may have 2 issues.
Steam wand may be blocked;
Try descaling the machine 1st before you do any thing else.
1.Try removing the steam tip, if you don't get steam with tip removed, try removing wand, if you don't get steam then the steam pin may be blocked.
If after descaling coffee is still jst warm you could replace thermostats http://www.bluestarcoffee.eu/ascaso--boiler-thermostats-x-2-193-p.asp
If you still don't have steam after descaling and replacing thermostats then you may need to replace the o rings on steam pin.
http://www.bluestarcoffee.eu/ascaso-gasket-kit-dream-arc-basic-114-p.asp
Ascaso descale sachets 10
Mar 31, 2011 | Ascaso Dream Espresso Machine
Overheating ascaso dream, and too much steam
You need to descale the machine and replace the group spring valve. It is available in a kit . Ascaso Dream gasket kit versitale version There are a number ok kits for different machnes
Jan 02, 2009 | Ascaso Dream Espresso Machine
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
