Question about General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator
GE #GFSS6KKXASS ice maker quit working. Test button on side of unit does nothing. Auger assy OK. Reseated harness connector. Any help?
ttech
  • 139 Answers
SOURCE: Replacing Auger in ice maker
Kim There are two Screws Holding the Complete Ice unit in Place,After Removing it it unpluggs inside the freezer,It would be advised to Replace the whole Unit ttech
Posted on Jul 20, 2007
  • 74 Answers
SOURCE: ge plastic auger ice maker fin broke off cleanly.
Replacement is the best solution as it can fall off and into the ice crusher and end up as small bits of plastic in your drink when you least expect it !! Look at the www.geappliances.com website for repair parts under service and support.
Posted on Feb 26, 2009
  • 5 Answers
SOURCE: GE PS123 MGNA CC Ice Auger
I just finished replacing the ice auger in my GE HSS25GFPA side-by-side and offer some suggestions/hints.
The auger (WR17X11705) was available locally (Appliance Parts Co., $28.97). This fits many other refrigerators. The replacement took a little under 2 hours. I estimate these hints may cut the time by one-half.
There are only 4 screws in the entire ice drawer assembly. It possibly was not necessary to remove the control rod. The other 3 screws hold the front cover. There are also 2 tabs holding the top of the cover.
The most difficult part of the repair was removal of the plastic assembly housing the crusher blades and the front bearing of the auger. This is held in place by only 2 large square tabs on the sides. There is enough space to get ONE side to release BUT to get both released required careful prying with thin-bladed screwdrivers (and prayer). These "tabs" don't push in, rather the drawer flexes out. Once released, the unit slides up and angles to allow removal of the auger/crusher. Re-assembly could not be easier. Stainless sheet metal screws would probably work if you do break something.
Remove the clear inside cover of the crusher assembly and the "C" clip on the threaded end of the auger shaft to separate the auger from the crusher.
And now for my PRIMARY reason for sharing my experience - the %#$@ plastic nut/bearing is a LEFT-HAND THREAD. I only realized this when trying to bend my make-shift split screwdrive back and the SOB loosened right up!
Carefully note the locations and orientations of the blades and spacers as you move them from the old to the new auger.
Posted on May 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ice maker problems
Not sure I understand your problem. If you would like a GE Ice Maker Service Manual I can email you one. Let me know, Sea Breeze
appliancepartsse@yahoo.com
Posted on May 24, 2009
MNfisherman
  • 11896 Answers
SOURCE: The ice maker works, but does not dispense
The bar, hinges or sensor may be broke or shot..
Posted on Jul 08, 2009
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Broken ice dispenser
try and remove the ice bin.the watch the auger motor while the door is open and the switch help close while some one is tryind to dispence ice.if the auger turns the check and see if the u shaped braket is stripped you can tell this by grabbing it and turning back and forth it should only move one way.if it does not turn then the auger motor does need to be replace.make sure to check the wiring as well.if the motor turn check th is bin and make sure there is no ice jammed in the teeth of the auger this wolud stopp it from turning.i hope this was some help to you good luck. would like to here how things go for you.
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE side by side fridge. Ice maker makes ice, but when I push the button on the front it just hums. Nothing spins.
you need to atake the ice bin out and thaw all the ice in it out. its causing the auger to be in a bind
Mar 05, 2009 | Whirlpool GS6SHAXMQ Side by Side...
Ice maker auger not turning
ICE MAKER NOT MAKING ICE ON MY GE SIDE BY SIDE FRIDGE.
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge ice maker
Sound like the auger motor behind the ice bin is not turning. Pull the ice bin out and you will see to metal fingers with bolt in the center can you turn this clockwise by hand? If not the motor is likely frozen you can pull auger assembly out by removing 3-4 screws unplug the harness then take to counter and warm up motor with your hair dryer until you can turn motor by hand. then reinstall
Nov 13, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Oct 31, 2008 | KitchenAid KSCS25IN Side by Side...
ICE MAKER
test the solenoid voltage in auger assy. its a little tricky.
Jul 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Refrigerator
check auger motor voltage or ohm out motor or direct test motor w/ 120 v.
Apr 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
1,054 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Shehu Pro
Shehu Pro
Joseph Mueller
Joseph Mueller
Are you a General Refrigerator Expert? Answer questions, earn points and help others
