Question about Gateway 505GR PC Desktop
Computer not showing anything
Hello have a gateway desktop computer fsp200 60atv and I tried to add memmory. As soon as I added the memmory the computer went off and ever since when I turn on the computer the monitor isnt coming on - blank monitor but I hear the system on .. the lights showing the HD is on.. inside on the mothermoard I see a blinking red light near the ethernet card...
Please help
  • msrinivasrao Jan 06, 2009
    my system is not showing any thing. but the cpu fan is working hdd & power led blinking.
    but in monitor nothing is showing
  • 30 Answers
Did you check the type of the memory card the motherboard of your computer would support? It may be a DDR1 or DDR2 and also check how much memory your motherboard can hold. You disconnect the memory card and check to see if the computer would turn on.
Posted on May 30, 2008
Installed 4GB upgrade in optiplex 330 still only 2GB memmory
Your BIOS should automatically detect your new RAM when your computer starts, try starting your computer after removing your old RAM module, if it starts, you need to update your BIOS to use 4GB. If it doesn't start, you either have a faulty RAM module or a faulty connector on your motherboard. Insert the new RAM module into the slot the old RAM module was in, if your computer still refuses to start, you have a faulty RAM module which should be returned, if it does start, it's the connector on the motherboard, and only replacing the entire board will fix the problem. However, it's worth noting that your motherboard will only support RAM modules of 2GB or less, the above was written with the assumption you're adding an additional 2GB module to your Dell computer.
Dec 24, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
I have a Gateway Desktop computer, and I have had it for a couple years, and it just wouldn't turn on. So I need to know if that means that computer is dead?
Check for any lights. Usually a computer would have a flea light on the motherboard as soon as you plug it in. If it doesn't have a flea light, start with the power supply. Swap the power cord of the monitor with the power supply of your desktop. If it still would not show power, try replacing the power supply. Worse case, you may need to replace the motherboard of your computer which would cost a lot.
Jun 27, 2011 | Gateway Computers & Internet
Gateway DX4200-09. Every couple of days the screen freezes and I have to manually power down. Sometimes it boots up right away other times it takes a couple of tries. What is going on. Is it...
You may be missing updates that are necessary for smooth operation of unit. Do you update automatically? Leave a comment in "add a comment" at end of solution.
Dave
Have you added or changed anything recently?
Mar 13, 2011 | Gateway DX4200-09 PC Desktop
My computer need to install more memory what i need to do
First you need to check your owner's manual or online at the Gateway site to find out how much memory your computer can hold and what type.
Then you need to see how many memory slots you have. You can then go out and buy the memory you need and remove the old and put in the new.
You may just be able to add memory if there are empty slots--otherwise, you'll have to remove the old smaller memory sticks and replace them with larger ones.
Jul 19, 2010 | Gateway Computers & Internet
How to add 1g ram to my gateway 838gm
Microsoft provides support for adding RAM at this page.
http://www.microsoft.com/athome/setup/addmemory.aspx
Your computer uses 400mHz DDR Sdram. It usually came standard with 512MB, which could have been 2 - 256MB modules or 1 - 512MB module.
Your computer will accomodate up to 4MB of RAM according to Gateway. You may consider putting in 2 -1GB modules as RAM is pretty darned cheap and it will make a nice difference in performance.
Nov 22, 2009 | Gateway Computers & Internet
Computer does not boot up
Computer has three short beeps as it starts? computer RAM (memory) related issue.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Hope this helps.
Oct 22, 2009 | Gateway GT5404 PC Desktop
Motherboard beeps three times, computer won't boot up
Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
Jun 13, 2009 | Gateway 506GR PC Desktop
Screen goes off showing VGA with cable on the screen
This looks like a bad cable connection. Try using a new cable for the connection between the computer and monitor. If that does not work test you computer on another monitor to make sure you are getting signal output from the video card.Also check the monitor on another computer.This is to check and make sure the monitor is working properly.You can also try using a add on video card in the computer to see if you can use the monitor this way.If you still are having problems. You can use this web address to get customer from Gateway. http://support.gateway.com/s/PC/R/1013953/1013953nv.shtml. I hope this helps you with your problem.
May 16, 2009 | Gateway GM5259E PC Desktop
Steps to add new hard drive to my dell dimension 2300
YOu can refer to this site..they are all the same procedure in adding hard drive in a computer.
http://www.infohq.com/Computer/adding-second-hard-drive-review.htm
melnavz
Nov 10, 2008 | Dell Dimension 2300 PC Desktop
Computer not showing on via monitor
Memory is Hard and you can destroy your computer if it isn't done properly because of many reasons. I would suggest that you remove the Memory and see if it works again but I must warn you that if you enter your computer without being a technician you may do further harm to your computer. If it works great but if not I will go through the steps of troubleshooting with you.
Hope This Helps
All The Best,
RCF
May 27, 2008 | Computers & Internet
Gateway 505GR PC Desktop Logo
193 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
