Question about Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher
Bosch shu6802 dishwasher impeller not spinning
4 Suggested Answers
  • 98 Answers
SOURCE: Our Bosch SHU 4300 dishwasher does not drain fully
There is a recall on the control board of many of these models, butyour problem is likely not related. A sticking impeller indicates that the pump may be failing, but you are welcome to try my guide to help. It is here. Thanks!
Posted on Jul 19, 2009
  • 457 Answers
SOURCE: Bosch dishwasher leaves water at the end of its
check for over sudzing. dont use a cascade with jet dry in it. use regular dishwashing liquid and fill jet dry compartment. you can even jet dry level by turning the knob in dispenser.
Posted on Feb 26, 2010
SOURCE: how do you fit a bosch dishwasher impeller jug
how do i locate the impellor jug on a bosch dishwasher sgv5303gb/13
Posted on Feb 08, 2011
Bosch goes straight to clean cycle
I had the same issue, for me this is what solved it.
Clean out the drain filter, remove any water that's still in there using a ladle/sponge/cloths, remove the impeller cover and make sure the impeller is spinning with no resistance. may be some food debris that got stuck or the filter may just be very clogged. Give it a try, it's a simple procedure:
This is from Bosch UK's youtube page:
http://www.youtube.com/watch?v=hfw3vliCf4c
Worth a try!
Sep 11, 2014 | Bosch Dishwashers
Bosch SHU43C07 impeller does not freely spin?
You will need to replace the Drain Pump Motor Assembly Bosch Part Number:AP2802385.
Most Bosch dishwashers are relatively straightforward to work on.
However, it you are not familiar with their disassembly and reassembly, you should take clear pictures of every part or wiring connection before you take it off or disconnect it. This will be invaluable when reassembling the dishwasher.
May 01, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch shy66c02uc
JESUS ALMIGHTY
Dec 18, 2013 | Dishwashers
Bosch shu6802 use and care manual
Oops! whats your question? If you need a manual, you can go on the Bosh web site to request one.
If your electronic board is giving problem....and the machine is more than 6 yrs old, and the user manual does not help..be prepared to buy new. The Bosh are good except when to board goes...
Oct 17, 2013 | Bosch Dishwashers
Dishwasher will not pump water out
The impeller of the pump-out pump siezes OR the impeller siezes because the water seals inhibit it from turning.
Problem well described in Owners Manual.
Yo may need to empty with a bucket initially.
Under the filter plates, there's a plastic access cover to the impeller.
You need to remove 1 Philips Head screw, the cover lifts off, and you can see the impeller, it is about 25mm (1") in diameter.
Remove any foreign material in or around the impeller.
Spin the impeller by hand.... it sometimes feels a little resistant, as though the seals on its shaft are gripping it.... this is OK.
Reassemble and try it out.
Good Luck
Dec 21, 2010 | Bosch SHU9915UC Dishwasher
Pump runs but nothing is pumped out
I just had a tech over,have the same problem with my SHE45M. Was told the plastic impeller is spinning on shaft. New to replace the drain pump.
Oct 16, 2010 | Bosch 24 in. SGS43C12 Classixx...
Model she44 won't drain
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Mar 25, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Water not draining
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Sep 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch SHU43C will sometimes make a loud noise
It may be more cost affective to just replace this unit. the circulation motors that are used in these dishwashers are not reliable. the wash impellers seems to have issues dealing with staying attached to the drive stud and shaft. this will cause the impeller ti shift inside the housing, causing noise and jams.
A new circulating impeller kit will cost about 100 dollars and, labor for this type of repair is 80 dollars an hour.
Jun 21, 2009 | Bosch Dishwashers
Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher Logo
51 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
