Question about Mitsubishi WD-52525 52" Rear Projection HDTV
The timer light is blinking and when i reset it, the timer light still blinks. Is the bulb no longer any good?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
This is a model prone to this problem.
In a nutshell all these sets develop this trouble. Google the model number and you will see what I mean.
I worked on a lot of these when new and also under extended warranty.
Three circuit boards are involved and any of them can cause this--bad filter caps on power, FM, or DM boards cause this problem.
At first you could order any of them and just replace, problem was the caps on all 3 were going bad--at 2-3 years they started dropping like flies. It was not strange for us to have 12 or more at one time in the shop.
Eventually it got so bad the boards were no longer available from Mitsubishi except on a rebuild basis and now that is gone.
To avoid a class action lawsuit over tens of thousands of these models (yours is the worst) they came up with a "solution"
About a year ago they started selling on an exchange basis the entire signal CHASSIS, it contains all three boards and the units are rebuilt---last time I heard only available through a Mitsubishi authorized service center and part wholesales for 200.
The problem with trying to repair the boards is you fix one and shortly after another fails etc.
Look into the Chassis exchange or consider another set. Needless to say I would not recommend another Mitsubishi DLP.
Let me know if you have questions.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Oct 05, 2010
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
I set my timer last night. the lights went off at the designated time this morning, but now the light is blinking. What does that mean?
Troubleshoot section in manual says, 'recheck wiring.'
Cut back insulation on stranded wire so stranded is longer than solid, Then wrap stranded around solid, and apply wire nut. After nut is tight, pull on stranded wire to make sure it is not loose:
http://waterheatertimer.org/How-to-twist-electric-wire.html
Check light bulbs are tight in socket. A fellow had same problem with programmable timer and discovered light sockets were dirty and not making good contact with bulbs.
If wiring is correct, try resetting timer.
Timer could be defective.
EJ351 has 1 year warranty against workmanship defects.
http://www.intermatic.com/customer%20service.aspx
Open following link for resources:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Intermatic Programmable 24 Wall Switch...
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
Blinking timer light - no other lights are blinking I have unplugged the TV overnight, replugged it in and hit the reset switch. TV will not come on. If it's a bad bulb, not sure why the lamp light is...
The blinking timer light is usually caused by bad capacitors on the DM board. The V26 DM repair kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and the Cd with instructions.
Dec 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking red light
replce lamp ballast board of your projector...
Oct 06, 2009 | Epson EMP 7500 Multimedia Projector
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
3 blinking lights - Samsung DLP
Remove your new bulb and examine the connector carefully. The inexpensive replacement bulbs tend to arc and ruin your $700 ballast; sad to say. If everything looks good, make sure the interlock switch on the bulb cover opening is engaging. It won't fire up if it thinks that door is open.
Dec 27, 2008 | Samsung Televison & Video
Blinking bulb light
Hi there
You must always reset the lamp timer when replacing a bulb.
Dec 11, 2007 | Dream Vision CINEXONE Multimedia Projector
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,438 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
