Hello, I just purchased and installed a Quaker propane house heater (model RVM-350A) in a cabin. Worked for first 14 hours great. Then it shut down per usual once temperature inside cabin was reached and a few minutes later I heared a "pop." A small yellow flame was burning in the chamber under the burner. This has repeated itself everytime it shuts down now. Sometimes it happens once or twice and sometimes it will happen 5 times before the heater starts again. Any idea how I can fix it? Also looking for a company that sells 20-30K BTU small propane vented heaters if you know of any? Thank you.....Mark
    Problem Solver:
  • 10 Answers
Sounds like a venting issue, check manufactures install procedures.
Posted on Oct 05, 2010
I have a Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU and the pool pump and heater work fine untim the next morning. The pool pump comes on and the heater does not. The service light...
How old is the heater?
When was the last time it worked correctly?
Does the pool reach the set point? If not, how close does it get?How long will the heater run (hours)?
What model pump are you using?
May 29, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Heater or gas failure ?
This seem issue with the control panel. did you made any change lately?
Sep 22, 2008 | Empire ECS HB06M HearthRite Heater
Model 640HORT Reliance 606 40 gal LPgas came to cabin, water cold, lit; ran for 4 hours, flame went out, burner won't come on.
It does sound like a weak pilot thermocouple. Change the thermocouple first. Make sure you have an adequate supply of propane serving the water heater. If it still works for a while then completely shuts down, you will need to replace the control valve. Call Reliance and see if the unit is still under warranty, you may be able to get free parts.
Sep 11, 2010 | Reliance & LP Gas Water Heater Control
I have an empire wall heater that was converted to natural gas how do i convert it back to propane?
you will need a propane conversion kit designed for that particular model heater.
which would most likely consist of a heavier spring for the gas valve and orifices for the burners depending on how many burners you have.
Most all gas heaters come thru the factory set up for natural gas and most have a kit available for conversion to LP (Propane) You will also need a manometer or a gas pressure tester to check the incoming and outgoing pressures from the green (2ndary )regulator outside your house to the gas valve inlet side,usually 11 to 14" WC( water column) pressure( static) 14" being MAX!!
Outlet pressure with burners running 10-11" WC approx. This info should come with the conversion kit if available. If you are not comfortable working with gas then find someone who is, for safety reasons.
Jan 31, 2010 | Reddy Heater RLP100 Portable Forced Air...
Blinking lights. Shuts off.
Hello, Mne was also shutting down. Turns out that is was clogged with dust, therefore overheating and turning it self off. If you're handy, you may want to open the heater and dust it off with a can of compressed air.
Worked for me.
Oct 02, 2008 | Lasko 5132 Ceramic Compact Heater
Pool Heater repair
Could be a regulator fault, thermostat, flow switch (pump) or ignition fault get unit serviced by a competent gasfitter
Jul 19, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Dayton Fuel Trimmer Shop Heater
flue diameter is 4 inch
Propane Unit Heater, BtuH Input 30000, Full Load Current 2.1 Amps, Gas Inlet 1/2 Inch, Flue Diameter 4 R,V, Motor Power Rating 1/30 HP, Free Air Flow 700 CFM, Height 27 1/2 Inches, Depth 27 5/8 Inches, Width 14 Inches, OC Mounting 8 5/8 Inches, 115 Volts, Energy Saving
Nov 20, 2007 | Dayton (3E379) Heater
Rinnai RHFE-1001FA
I can suggest a around-about solution. I also have the same model installed around the same time. I have the outlet that it is connected to controlled by an electric heat thermostat on a wall at the oposite side of the room. I keep the heater on high at all times and the thermostat controls the electricity to the outlet. It's worked great for the 13 years it's been installed.
Mar 11, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
