Question about Frigidaire FGQ332ES Gas Dryer
Just bought a used frigidaire crown series gas dryer need a hook up line in the back to connect the gas. Is it a certain size i need or how do i find out
  • Frigidaire Master
  • 43,501 Answers
The line size depends on three things...the BTU of the burner and the length of the line...and the types of gas..Natural or LP
To find the line size you nees a chart that gives you the sizing based on these factors...
Here is a chart for Natural gas and I'm sure LP is also in thei site if you need that...
http://www.engineeringtoolbox.com/natural-gas-pipe-sizing-d_826.html
heatman101
Posted on Oct 04, 2010
My frigidare heavy duty crown series gas dryer is n0t heating and barely able to dry my clothes--what could be the problem and how can i fix it
Hello Chuck, thanks for your inquiry
Based off the information you have provided I have identified a few possibilities as to why your dryer is not heating could be the element, thermostat, or control panel. Each component controls the heat within your dryer and if one goes out it is possible that can cause the rest to not function properly. To accurately find out the reason to why your dryer is not heating I would recommend having a professional come out. Hopefully this is helpful. -Matt
Sep 28, 2014 | Frigidaire Dryers
Frigidaire dryer crown series model #FDEB23SRGS1 will not start
Check the breakers first . Reset both poles even though they may not show tripped. The wiring t the receptacle or plug could be loose. Los check behind it behind the back panel.
Feb 03, 2013 | Frigidaire Dryers
What size gas connector do i need for maytag gas dryer pyg2300aww
The size where the nipple that ya connect to that sticks out the back of dryer is 1/2inch..now your gas pipe in the house could be 1/2" or 3/4" so in that case if it is 3/4 you would need 1/2" connecter at the dryer and a 3/4" by 1/2" reducer to connect at your house gas pipe
while i am all about the can do spirit... certain things that if done impoperly can blow up your house should be done by professionals that will do it correctly
Aug 24, 2011 | Maytag PYG2300A Gas Dryer
BOUGHT A USED STACKABLE FRIDGIDAIRE AND NEED THE PLUG FOR IT, WHERE CAN I GET IT? WHERES THE MODEL NUMBER ITS A HEAVY DUTY CROWN SERIES
The Model number could be on the top of the machine or around the dryer door or by the washer lid. if your looking for a 220/240 volt 3 prong cord you should be able to get one at lows or home depot
Jan 09, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I HAVE A AMANA FULL CAPACITY 7.1 DRYER THAT NEEDS A FITTING THAT HOOKS ON THE BACK OF THE DRYER INTO THE GAS LINE
If you are talking about the adapter between the flexible gas line and your dryer, your local hardware store will have it. I usually recommend that you take your flexible gas line with you so they can match up the correct size. The dryer gas pipe is standard. Good Luck, Appliance Specialists
Jan 04, 2010 | Amana ALG331RAW Gas Dryer
Where is the gas input located on the back of a duets dryer. I need exact location to purchase correct length gas line prior to delivery tomorrow.
The standard dryer BTU rating is 22,000 btus. A 3/8 connector by 60 inch will be good enough to handle it. Just make sure that you get the size that matches you gas line valve flare fitting. The connector should hook directly up to the gas line valve without an adapter. The adapter will come with the connector and that goes on the pipe thread connection at the back of the dryer. You only need to use PTFE tape or sealent on the pipe thread at the back of the dryer. You do use any tape or sealent on the flare fittings.
Oct 13, 2009 | Dryers
Dryer tub turns but there is no heat
I have a frigidaire crown series dryer.the tub turns,timer works but there is no heat coming out.
Jun 23, 2009 | Whirlpool Dryers
This is our 2nd new Maytag Performance Series 5000 gas dryer. Bought at Home Depot. Originally bought w/d and they just dumped the pair off. Had to hire a plumber to come and hook the gas up. Washer works...
No solution. In fact we just bought a new 5000 dryer and it did 4 loads before DYING. Will not dry at all and machine definitely is turned on. Currently struggling to get it replaced.
Apr 10, 2009 | Maytag MGDE500V Dryer
Bought cherry lg tromm dryer, bf ruined the gas line hook up (tried to fit the wrong size hose) can this be fixed and what can we do?
if the threads are ruined on the dryer unit itself, id reccomned calling in an lg authorized repairman. if it has to do with gas line installation go with a liscenced plumber.. why mess with GAS in home.
Mar 04, 2008 | Dryers
Frigidaire FGQ332ES Gas Dryer Logo
123 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
