Question about GE Refrigerators
Refrigerator and Freezer settings are blank and motor is "clicking"
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 04, 2010
Samsung RB31F Fridge/Freezer - fridge temperature too high, freezer OK
1-The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty-if the condenser coils are dirty, clean them.
2-The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Oct 29, 2017 | Samsung Refrigerators
Motor runs for 5 seconds then clicks off
We had our system Kenmore Elite not keeping the freezer cool or the refrigerator. I pulled out the unit and cleaned the condenser coils. This solved our issues, hope this helps.
Jan 05, 2014 | Kenmore 74252 / 74254 / 74259 Top Freezer...
Motor not running, not cooling in refrigeratir or freezer ice is melting and dripping out the lights are on inside, but there arae no lights on the front panel the unit is turned on the settings are...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 25, 2011 | Whirlpool Refrigerators
My amana refrigerator abb1924dew is making a sound like it the motor wants to rev up but it goes back down. In addition while this is happenning, the electrical panel which reflects the setting blinks...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Nov 02, 2010 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Freezer, and refrig not cooling....ice maker stopped working too.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
tygjcn
Jul 09, 2010 | Jenn-Air JCD2389G Side by Side...
Noisy refrigerator/freezer
The freezer fan motor , being noisey , is probably the cause for the food/drink problem . It should be replaced . Pt # 54482-10 is the part number for the motor . However , on your model , it looks like the bottom freezer panel , has to be removed , to replace the motor . The motor costs about $70.00 . Do not know if you should try this yourself , may need an experienced repairman , to remove the divider strip , to remove the panel .
Oct 11, 2009 | Refrigerators
Stuff in the freezer is melting, motor is running, no cold
turn your freezer temp dial to off and wait 30 seconds, then turn it back on to max setting. if you have temp gauage you can try to check temp inside freezer, if not cold enough (less than 30 degrees) you could be losing freon gas. you need to call technician.
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My bottom freezer is not cold
  • Is the thermostat knob turned to the proper setting? If not, reset it.
  • Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator/freezer at the back near the bottom. If it is humming or making a continuous noise and your refrigerator/freezer is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator/freezer, there may be a problem with one or more of these:
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
    Aug 16, 2009 | Refrigerators
    Kenmore elite 596 73503201 no cooling in top compartment
    if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
    REFRIGERATOR TROUBLESHOOTING
    #1 Refrigerator side getting warm Freezer still cold
    Evaporator fan motor not running.
    Defective defrost timer. See Defrost Diagnosis Procedure
    Defrost heater defective. See Defrost Diagnosis Procedure
    Defrost thermostat defective. See Defrost Diagnosis Procedure
    Airflow blocked from freezer compartment.
    Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
    Fan blade broken.
    Defective door switch on older models.
    Light staying on with door closed.
    2 Refrigerator & freezer compartments both are getting warm
    Make sure refrigerator is plugged in and has power.
    Condenser fan motor on bottom under refrigerator not running.
    Condenser coil clogged.
    Defective defrost heater. See Defrost Diagnosis Procedure
    Defective defrost thermostat. See Defrost Diagnosis Procedure
    Cold control defective.
    Compressor overload defective.
    Compressor relay defective.
    Compressor defective.
    Low on refrigerant. #3 Freezer compartment getting hot.
    Defrost timer stuck in defrost cycle.(replace)
    Defrost thermostat stuck.(replace)
    Ice maker stuck in harvest cycle
    Light staying on with door closed. 4 Ice maker not making ice
    Defective inlet water valve.
    Freezer temperature not cold enough. (see problem # 2 & 3 above)
    Defective thermostat in ice maker.
    Defective drive motor.
    Water inlet tube clogged with ice.
    Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
    Door gaskets leaking air.
    Defective case heaters.
    Energy saver switch not set to reduce exterior moisture
    also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
    Mar 27, 2009 | Refrigerators
    Refrigerators Logo
    37 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
