Question about Canon PIXMA MP610 InkJet Printer
Horizontal stripes appear when we print - Canon PIXMA MP610 InkJet Printer
    President:
  • 1,335 Answers
This typically means that either the printhead needs alignment or the nozzles may be partially clogged.
If you are using aftermarket or refilled cartridges, change to new OEM cartridges and run the cleaning and alignment utilties.This normally clears clogged nozzles.
If you need a manual you can download it from
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp610#BrochuresAndManuals
Posted on Oct 05, 2010
Testimonial: "thank you!!!"
How do i re align the head on aMX432 cannon
  1. Open the printer driver setup window
  2. Click Custom Settings on the Maintenance tabThe Custom Settings dialog box opens.
  3. Switch head alignment to manual
    Check the Align heads manually check box.
  4. Apply the settings
    Click OK and when the confirmation message appears, click OK.
  5. Click Print Head Alignment on the Maintenance tab
    The Start Print Head Alignment dialog box opens.
  6. Load paper in the machine
    Load three sheets of A4 size or Letter size plain paper into the front tray.
  7. Execute head alignment
    Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  8. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    When you have entered all the necessary values, click OK.
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/EN/PPG/images/i_note.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
      (B) Most noticeable vertical streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
      (A) Least noticeable horizontal streaks
      (B) Most noticeable horizontal streaks
  9. Confirm the displayed message and click OK
    The second pattern is printed.
  10. Check the printed pattern
  11. Confirm the displayed message and click OK
    The third pattern is printed.
  12. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
      (B) Most noticeable horizontal stripes
Jan 05, 2015 | Cannon Office Equipment & Supplies
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
  9. Check the printed pattern
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
  15. Check the printed pattern
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
Prints B&W in Horizontal Stripes
I received an answer elsewhere. Thank you.
Jan 26, 2010 | Canon Office Equipment & Supplies
Printer prints stripes through images
your printer needs to be cleaned. Use the cleaning mode in windows printer HPOFFICEJET
Sep 18, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
Horizontal stripes on images
may be the ink level in ur ink jet printer is low try and use genuine ink for ur printer . i also have the same problem . when i replaced with original ink it gets ok
Dec 03, 2007 | Canon BubbleJet i560 InkJet Printer
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
Colour printing
If the test patterns are not matching what your printer tells you is normal and your photos are banded horizontally, you may have clogged nozzles and printhead. Do a maintenace clean under your printers direction, and see if it now prints ok. Also, you may be low or out of one particular colour, but still have enough of the others and the printer will try to compensate by using available colours, hence colour banding and distortion. A manual clean with cotton buds and cleansing solution is recommended if the first clean does not help.
Dec 12, 2006 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA MP610 InkJet Printer Logo
434 people viewed this question
old marine
old marine
