Question about Canon EOS 450D EOS Rebel XSi Digital Camera with 1785mm and 70300mm lenses
My camera is suddenly having issues focusing. It won't take pictures in AV mode, I press the button to auto focus and take the picture and nothing happens. Occasionally the screen says "system busy". What is going on?
  • 567 Answers
Try to configure the buttons from your lens as described below:
Button AF/MF: to AF
Button STABILIZER ON/OF: to OFF
The camera takes a longer time to focus when the ambient light is less.
Also, try in other modes, like Tv and Auto, and see if the camera focuses.
You may also try to:
1. Detach the lens from the camera
2. Turn the camera off.
3. Format and remove the Memory Card.
4. Reset all camera settings.
5. Remove battery and wait 2 min
6. Then insert battery, card and attach lens.
If it does not focus in bright light and in other modes and you have also tried all the steps above, try giving the contacts on the lens and camera a wipe with a dry cloth.
No liquid at all please.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
Posted on Oct 05, 2010
Won't take a picture, flash or focus
may be the snap button is not working, apply some contact cleaner around the button press it an release several times, it will work.
Feb 26, 2016 | Samsung S760 Digital Camera
Why won't my fugi finepix s4500 won't focus sharply ?
No good working auto focus can have many causes.
Like the camera is in Macro mode, or manual focus. The best thing to try, is to switch your camera to the auto mode. The camera logo on your mode dial. And then shoot some pictures. There should be enough light and contrast in the frame, on the place you want the camera to focus on. Sometimes you have to chose an object, with enough details and contrast, on the same distance as the object you want to take a picture of. Then press the shutter half way, till the camera is in focus. the indicator lamp next to the mode dial glows green. Then frame the picture like you want it taken end only than press the shutter completely.
If the camera does focus correct in the auto mode, then you can check, why it did not focus before.
Check page 19 of the manual, to see how to use the shutter release button, for correct focus.
Apr 23, 2014 | Fuji Finepix S1500 10.0 Megapixel 12x...
My daughters 350d will only take pictures in manual focus mode, in auto focus it all seems good but it won't actually take the picture? Any ideas?
Shutter Assy, Mirror Assy or Shutter Button taken a coffee breaks.
You did try using a new battery?
Or your battery is not over 3 years old?
If I can help, just send me an email.
atdlee@netzero.com
Dec 30, 2012 | Canon Rebel XT / EOS 350D Digital Camera
My fujifilm fine pix av 190 camera does not shoot when pressing shoot button....i have to press hard to shoot...
That camera could have two things causing it, 1 the soft press is the auto focus. Most cameras have a half press or soft press to turn on the auto focus and the hard press or press to take the picture. That could just be the camera. Some cameras that can be turned off in the menu. If that is not the case and it does not auto focus when you press it, then it is the button. We used to see that a lot with cameras. The button gives sometimes.
Oct 18, 2012 | Fuji FinePix A345 Digital Camera
My photo's are not sharp and clear. What am I doing wrong?
you could be doing nothing wrong, These cameras have auto focus and when there pas there prime, you need to get them fixed basically.
If the output is out of focus more then likely the auto focus is your issue.
Hope this does help, would be considerate if you do leave a rating or feedback before you go, Thanks
Sep 04, 2010 | Panasonic SDR-H80 Hard Drive Camcorder
What do i do if my camera is taking blurry?
try this steps
-make sure that the mode dial is in AUTO
-half press the shutter button and let the camera do an auto focus thing
-then full press the shutter button
if that does not work reset the unit press MENU > SET UP 2 . RESET this will restore the unit to factory settings and will not erase your pictures
then try this steps again
Jul 01, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
Auto focus not working
The lens AF mode is not working. What lens is it you are using?
It is not a camera issue but a lens issue. Try a different lens to be certain.
Jun 08, 2009 | Canon EOS 40D Digital Camera
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
Auto focus
Are you sure you did not activate "Manual Focus"?
Near the shutter button, there's a "Focus" button. maybe you pressed it accidentally and now you're in "Manual Focus" mode.
If so, press it once more to get "Multipoint" mode back to life...
And read the camera manual. It's a goot place to look for this kind of answers.
Jun 09, 2008 | Sony Cyber-shot DSC-H5 Digital Camera
Cybershot H7 focus problem
Things to check before you assume it is a mechanical issue-you can get vibration message if flash is disabled, be sure also that the macro mode is not enabled-this is very common on sony cameras to turn on by accident-flower button on camera will put in close up mode and you will get blur make sure no flower is present on lcd screen-if in macro press button on camera w/flower to turn off-also in menu you have continuous and monitor auto focus settings try changing one or the other and see what happens
Mar 18, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Canon EOS 450D EOS Rebel XSi Digital Camera with 1785mm and 70300mm lenses Logo
126 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
