Question about Maytag MFC2061HES Stainless Steel French Door Refrigerator
Internal water dispenser makes horrible loud noise....like a pump is sucking air or something....
3 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: Ice dispenser appearing to get stuck in the open
The noise is probably the solenoid which operates the door or the one that switches it from cube to crushed ice. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Here's a diagram of the dispenser which may help.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48122&diagram_id=656733#d656733
Posted on Jan 08, 2010
  • 3 Answers
SOURCE: icemaker makes a loud buzzing noise when
If it just buzzes & doesn't actually dispense any ice, you may have a broken dispenser door. We have just had to replace ours for the same reason. We have a Maytag MSD2732GR side-by-side
Posted on Jul 23, 2010
What could be causing loud grinding noise when i switch on aircon? Aircon now not working but only makes loud sound.
Sounds like the bearing or part of the clutch in the A/C compressor has failed, or possibly component on a/c fouling on something due to recent repairs however would be unlikely and probably just a coincidence..
Check A/C compressor turns by hand, should be firm but not make any noises.
Check for fouling components related to a/c compressor clutch.
Feb 12, 2016 | Cars & Trucks
Replaced water filter when trying to get water it HONKS loudly and no water comes out
You might have air in your system. Hold the dispense lever down for several second about every 10 minutes until you have the air purged.
Jan 15, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
New out of the box. won't dispence water to make espresso
Hi. Is your pump working. Should be able to hear it. If its making a really loud noise then it could be an air lock in the line. Try using the hot water button to bleed the system. Also see if it will despence water wiyhout any coffee in handle. Dazza REPAIRER
Sep 23, 2011 | DeLonghi EC155 Espresso Machine
Makes a horrible noise when it is draining
Either something stuck in the pump or the pump bearings need lubricating. It is easy to remove buy tipping the machine back at 45 degrees, the pump is under right front and is removed by turning anticlockwise.
Apr 19, 2010 | Fisher and Paykel IWL12 Top Load Washer
Makes loud vibration noise (not there when
brewer needs to be descaled use and care guide recomend it to be done every 3 months. Do it religiously according to that time frame regardless of how filtered your water is
Mar 16, 2010 | Keurig B60 Coffee Maker
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
Loud noise
Not sure I understand ....is the pump making a lot of noise?
If so it might have sucked in some air. Run some water through your steam pipe until all the air has been pushed through.
Jan 08, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Maytag MFC2061HES Stainless Steel French Door Refrigerator Logo
53 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
