Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer keeps filling with water during spin cycle
gwshaw71
  • 83 Answers
SOURCE: Agitator Not Working
check your motor coupler, lid switch
Posted on Dec 07, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore washer...the water just runs it never fills up.
I have seen this problem numerous times on service calls. It sounds like you have a siphoning problem. The key symptom is the wash tub that continously attempts to fill, but cannot achieve the proper water level. This is often caused by not having an air gap on your drain line, improper placement of the drain hose, or a standpipe that is too small in diameter. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If you place the drain hose in the standpipe too far, or seal the top of the standpipe, this can cause a vacuum which will cause the symptoms you describe. A tell-tale sign will be a sucking noise as you pull the drain hose from the standpipe. Read through the link I provided. If this does not correct your problem please post back and let me know before you rate this solution. This way I can try to assist you further. I hope this corrects your problem.
Posted on Feb 25, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
aasc
  • 1606 Answers
SOURCE: kenmore series 90 washer keeps filling with water
If overfills onto the floor , then the waterlevel switch hose came off the switch behind the control panel . You have to remove the 2 side screws and tilt panel to see the hose and switch . If the water keeps filling , but doesn't go on the floor , then you have a syphon problem at your drain . As it fills , water is being sucked out by your drain due to no air able to get in around the drainhose and drainpipe . Pull drain hose out of drain and only insert about 4-5 inches into drain . If hose is tightly in drain , a parts house or home depot should have a syphon break in stock .
Posted on Jul 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fill or drain but does not spin
It's not supposed to spin during water fill and draining, if I understand your post.
Charlie
Aug 23, 2009 | Kenmore 44102 Front Load Washer
Kenmore washer fills during spin cycle and doesn't drain completely
HI, this is just a slight clog or faulty drain pump. check the following areas.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 18, 2009 | Kenmore Washing Machines
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Brand new kenmore HE2 front load washer - keeps filling
Either your pressure switch is bad, or the air line that connects to the presuure switch has come loose. The pressure switch is located on the right-hand side rear of the washer with the top cover removed. It is a brown colored, disk shaped, device with an electrical connection and an air hose connection. Sometimes this hose comes loose in shipping, or the electrical connection may be loose. Without it, the washer will continue to fill and will NOT shut off. Now...if you just purchased this unit, DO NOT do anything that will void the manufacturer's warranty. It may be an inconvenience, but I would recommend you get the appliance repairman to come in and take a look at it. That way...you won't be held liable if something were to break. This is, however, usually a simple problem and not considered major. I hope this reassures you some. Post back with comments if you have any further questions/concerns.
Nov 11, 2007 | Kenmore 46462 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
165 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
