The outside air handler is not working. - Heating & Cooling
  • 674 Answers
Check the circuit breakers or fuses first. I'm assuming that the inside unit is running. If the unit has power, remove the small cover where the power goes in so that you can see the contactor. Next set the thermostat to make the unit come on and check the contactor to make sure that is has been pulled in and check for power on the load side of the contactor. If that is good then check the capacitor. If it looks swollen then it is bad otherwise check it with a multimeter or get a heating and air supply store to check it. If the contactor isn't pulled in, remove the face from your thermostat and place a jumper wire between R and Y. If the contactor pulls in then, the problem is your thermostat. If it doesn't the problem may be your contactor. Let me know what you find.
Posted on Oct 05, 2010
Fans working outside but no air is coming inside, on my 3 ton air conditioner
Check air handler up in attic follow stat to power box on handler look for blown fuse.pull power at unit first
May 22, 2014 | Coleman Propane Forced Air Heater...
Need wire diagram from T-stat to Air-Handler then cond unit
green goes to g on air-handler,white goes to w on air-handler yellow goes to outside condensor, red from air-handler goes to rh-rc on thermostat, whire off c on air-handler goes to outside condensor.
May 13, 2014 | Ruud Heating & Cooling
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
My outside A/C unit is not coming on
might be it is relay problem in pcb. Pls check the cord then relay by a technician,
Oct 14, 2013 | Goodman Heating & Cooling
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
I have a T3BA-036KA the outside unit will not
You need 24 volts going to the coil of the contactor. If you do not have 24 volts, you will need to trace the wiring back to see where you are losing it from. Try placing your voltmeter at C & Y coming from your air handler. If not, go to your air handler and test for 24 volts ac at C & Y coming from your thermostat. If you do not have 24 volts coming from your thermostat, there is either a problem with the thermostat or there is a problem with the wiring between the thermostat and the air handler. If you have 24 volts at the air handler coming from the thermostat but you do not have 24 volts at the outdoor unit coming from the air handler, then you have a problem with the wires between the air handler and the outdoor unit.
I hope you find this information to be very helpful to you moving forward. Please leave a rating. :-)
May 10, 2010 | Intertherm P3RA-036K Air Conditioner
Air handler turbine fan does not come on
A bad fan relay is not sending high voltage to the fan. A defective thermostat not sending low voltage to the fan relay.
How did you check the fan to say that it works?
Sep 25, 2009 | Ruud UBHC Air Conditioner
Inside unit freezing
There are varius items that make the unit inside (air handler) freezes up .If the fan motor in the air handler doesn't work it'llice up.If the filter is dirty it'llfreezes up. If the coil in the air handler is dirty it will freezes up.And if the unit is low in refrigerant(freon) it'll ice up.If is low in gas means there's a leak and before recharged it needs to be fixed.
Apr 23, 2009 | Heating & Cooling
Where is the fuse box in the inside air handler?
There should be a small 3 or 5 amp fuse on the circuit board inside the air handler.
Apr 19, 2009 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
