Question about Cycling
The gears are really difficult to change. What do I need to do to make them easier to change?
    Scholar:
  • 81 Answers
There a few things you can do. First, give your chain a good lube with some quality chain lube. DON'T use WD40, that will make things a lot worse. If your chain isn't the problem, then it could be the cables are gunked up in their housings. Mud and dirt can enter the sheath of the cable and cause them to stick. Rust can do the same thing. Try replacing the cables with new ones, and make sure to have them done by someone who knows what their doing. You don't want to lose your brakes unexpectedly, it's best to have a professional you trust change them out for you.
Posted on Oct 05, 2010
Cant get car into gear
The Syncro Gear in your Transmission is probably gone. Requires a rebuild. The Syncro is what aligns the metal gears inside the transmission and allows you to shift smoothly between gears and to get the alignment right. When you FORCED the shifter, you did more harm than good...
Mar 01, 2014 | Toys
Freelander clutch
check out the operation of the clutch system .IT is difficult to rationalise a hydraulic clutch because if it is slipping that means that the pressure plate is being held off and not fully engaging but it also means that when pressing on the clutch the there would be no problem changing gears . But if you have a cable clutch operation then it is possible that the cable is jamming inside the outer cover and holding the pressure plate off ( slipping) and gear problems. If it is cable then replace the cable first. If hydraulic then it may mean box out for a new clutch kit.
Jan 12, 2014 | Cars & Trucks
Why is my gear shift so hard to move??
I believe your clutch is not disengaging fully. When this happens it may be hard to get into first gear but subsequet shifts are easier due to the fact the vehicle is moving. You probably have a hydraulic clutch system which is low on fluid or may have air in the system. Before shifting into first gear or reverse try pumping the clutch pedal 5 or 6 times then shifting, if it goes into gear easier after this then you probably have air in the system, it can be bled similar to bleeding brakes. If this doesnt work you might be low on fluid, or have a bad master or slave cylinder.
Aug 28, 2012 | 2002 Hyundai Accent
How difficult to change the link bolt on the front right stabilizer bar? 96 sonoma 2 wheel drive.
It's really just grunt work, you need 1/2 inch drive sockets and a braker bar or a big rachet, and a 4 lb. sledge hammer makes it much easier.
Mar 09, 2011 | 1996 GMC Sonoma
How does the distributor housing and gear get lubrication
Your distributor gear is oiled by runoff that drips onto the corresponding gear on the camshaft. by design, a small amount of oil is either drawn up the shaft or is introduced by a small oiling hole in the side of the housing if needed. The bushings in a distributor are often made from oilite which is bronze with a lubricant impregnated into it, or aluminum that has been chemically hardened to prevent wear.
Replacing distributor bushings used to be common but today, it's really difficult to find bushing sets so it's generally easier to just replace it with a rebuilt one.
If your engine is eating distributor gears, look into the hole where the distributor goes and check the cam gear. If that gear is damaged you may need a new cam. In that case I'd also check cam end play. If excessive you may need to replace a thrust plate or add a thrust button to limit movement. (depends on which engine you have)
Feb 21, 2011 | Jeep Wrangler Cars & Trucks
I have a Toyota Corolla AE 100 manual gear shift gets stuck
why my 2006 corolla car gearbox is stuck in third gear and cannot move
May 29, 2010 | 1991 Toyota Corolla
I have been given a bike with Shimano gears.Left hand 123,Righthand 1234567.Can you give me a normal setting to start riding using them and getting used to them.
I would start out with the left gear set to 2 and the right shifter set to 4 or 5. If that's too difficult, then shift the left gear to 1.
Most people really don't shift gears on bikes much and that's a shame because it can make cycling much easier. I would advise you to take some time to learn about shifting as it will make riding much easier, especially if there are any hills around.
The left hand shifter is for the 3 large gears in between your pedals. This shifter produces the biggest change in effort. As a general rule, use the first one for uphills, the middle for flats and the last one for downhills. Of course this is all relative to your conditioning. You should attempt to maintain a pedaling cadence of 75-90 (in general) so that you always feel like the pedals are spinning and that you are not grinding it out. The right hand shifter is for the 7 gears on the rear of the bike and are used for smaller changes. Here is a link that will provide more detailed info on this subject. Happy cycling!
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
Mar 03, 2010 | Cycling
Motorcycle: Difficulty changing up to 2nd gear and neutral
one thing, check your gear selector, sometimes if that sharp edge is rounded out, worn out from usage, your gears may either slip, or wont wove at all.
Sep 10, 2009 | 1990 Yamaha XT 600 E
Hard to Get into Gear?
Either your clutch is not fully dis-engaging or the transmission synchros are worn. Check the clutch master cylinder for level and check system for any leaks if it is a bit low.
Aug 31, 2009 | 1989 Honda CRX
It is very difficult to engage the first gear of my skoda fabia
Exchange the transmission fluid with a synthetic lube for easier engagement. Shift to second first before shifting to first helps as well.
Jul 26, 2017 | 1989 Saab 900 4 Door
Cycling Logo
55 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
