Question about Microsoft Windows XP Home Edition
How to repair standby task button on turn off menu.
    Guru:
  • 846 Answers
This problem is because you haven't installed VGA drivers
Download this http://www.devicedoctor.com/device-doctor-download.php
It will update(Download) all the drivers needed by your PC
**Don't forget to rate...If you find my solution helpful**
Have a Nice Day
Posted on Oct 04, 2010
Testimonial: "Thank's Nitin_Master this resolve my problem.andrew3"
Yb125 battery wont charge
Instructions
    • 1 Check the main power cord if the receiver fails to turn on. If it is unplugged or loose, securely plug it in to an electrical outlet. If this fails, try plugging the receiver in to another outlet. If the receiver starts, the previous outlet is damaged. Call an electrician to repair it. If this fails, try turning the receiver on with the remote. If this does not turn the receiver on, try turning it on with the power button on the receiver itself. If this works, change the remote's batteries.
    • 2 Leave the receiver in "Standby" mode if it immediately goes into "Standby" when you turn it on. With the receiver still in "Standby," unplug the main power cord. Wait for around 30 seconds, then plug the receiver back in.
    • 3 Check the audio cables if you experience sound issues. If they are loose or disconnected, securely reconnect them. If you still do not have any audio, press the "Input" left or "Input" right buttons on the front panel to select the appropriate input source. You can also set the receiver to automatically detect input signals and select the appropriate input source. To do this, access "Audio Select" from the main menu and select the "Auto" option.
    • 4 Try factory resetting the receiver if you experience persistent audio or video issues. Press the "Standby/On" button on the receiver's front panel. Press and hold the "Tone Control" button, then press "Standby/On" again. Select the "Preset" option, then choose "Reset." Press "Standby/On."
Jan 14, 2013 | Yamaha Motorcycles
No start task bar in safe mode
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe.
If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
Jul 06, 2012 | Dell OptiPlex GX260 PC Desktop
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
Start menu and task bar is not responding for a mean while after i turn on my computer.
Please follow the given steps to relaunch the Start Menu and Taskbar:
1. Press Ctrl + Alt + Del or Ctrl + Shift + Esc to bring the Task Manager.
2. Go to Processes TAB
3. Find explorer.exe and select it
4. Click End Process (Button at Bottom Right Corner)
5. Click File Menu and Select New Task (File-->New Task(Run))
6. type in explorer and press ok
May 18, 2011 | Microsoft Windows XP Professional
My KDL sony tv turns on briefly(displays menu) then shuts down, and standby led flashes 6 times then pauses then continues, does not respond to the on/off button or the remote
6 times blinking standby light indicates problem with Audio Section in tv
Check AU 15V output of G2 (power supply) board then check AU board as it has sound processor and sound output ICs.
If you are not familiar with electronics stuff repair then call local tv repairman to repair it for you.
Thanks.
Oct 29, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Standby button flashes i have sound but n o picture it just flashes the standby button for the sony big screen 57 please help
Its possible that the CRTs have shutdown due to a vertical failure. Have you tried pressing menu to see if the onscreen menu will come up, as often the menu will operate when the crts go into blanking for protection. You can also try turning up the CRTs slightly to see if they will turn on.
Nov 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Aux problem
You have to go into the standby menu and turn aux on. Go to standby, push menu button and scroll down to aux and turn on
Aug 05, 2009 | Kenwood KDC-MP235 CD Player
ThinkPad T60 Desktop Not Restored After Hibernation/Standby
there is something that runs most of the interface between the user and the computer it is called explorer.exe to get the task manager open, you can try pressing CTRL+Shift+Delete another alternative is to do an OS reinstallation.
To get explorer.exe
1) press Ctrl+Alt+Delete; in unsuccessful try Ctrl+****+Delete
2) if task manager opens click on 'New Task..." (if task manager does not open, consider reinstalling your OS or simply don't go into standby/hibernate)
3) Once you get the New Task dialog box, type explorer.exe or C:/Windows/explorer.exe
Jan 01, 2009 | IBM ThinkPad T22 2647 Notebook
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Thanks
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
Unable to turn off DEMO MODE
1. Turn Radio On
2. Change Source input to Stand-By
( Puts radio in display only Stand By mode.)
3. Press Menu Button
( Gives you standby menu)
4. Toggle display with control knob until DEMO ON appears
5. Hold control knob in until DEM0 OFF appears
6. Press Menu Button
7. Change source back to music.
All done. same as other Fixes - Just step by step!
Sep 09, 2007 | Kenwood KDC-MP435U CD Player
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
