Question about Dymo LetraTAG Thermal Label Printer
Dymo Letratag Display Screen
When I type something, the first four letters show on screen but the next two don't... eg LETR AG But then they show up again. Print out is no problem but I can't see everything on screen.
  • keen_reader Aug 08, 2008
    I have a similar problem - only the bottom half of my letters show up on the display screen. No problem printing - but this is issue is annoying!
  • aeming4u Aug 19, 2008
    same problem i just have to guess if i punched in the write letters or not
whitesox
  • 64 Answers
SOURCE: Dymo LetraTag 2000 hand held printer
This Unit does NOT take ink. That is one of it's "benefits." Since it uses heat transfer, im thinking it either needs new batteries, or it's heat device has been expended. This is a cheap little maker, so it isnt made to handle the abuse of an office: it's meant for a label from week to week. If you went on a label spree all over the house, you killed it. Hope this helps!
Posted on Jul 26, 2007
  • 19 Answers
SOURCE: won't print
Here is the Dymo site for this issue:
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_alp.php?p_li=&p_accessibility=0&p_page=1&p_cv=&p_pv=2.22&p_prods=21%2C22&p_cats=&p_hidden_prods=&prod_lvl1=21&prod_lvl2=22&p_search_text=&p_new_search=1&p_search_type=answers.search_nl
Type "light print" into the search box and the first result is the link you are looking for.
Here is the text of the link:
Poor Print Quality from Electronic Labelmaker trnsp.gif Question I have an electronic labelmaker that is printing poorly. The print on the label is either very light, incomplete, or striped. How can I resolve this?
trnsp.gif Answer Proceed with the solutions listed below if you have an electronic labelmaker. If you have a LabelWriter printer that is printing poorly, click here.
Solution 1:
Replace the existing batteries with a new/fresh set of alkaline batteries. The print head requires a significant amount of battery power to ensure proper printing on the label. Light print on the label may be an indication that the batteries need to be replaced.
Solution 2:
Replace the existing tape cassette with a new tape cassette. Light printing may be an indication of bad label stock.
Solution 3:
Using the special brush supplied with your labelmaker (located on the inside cover of the cassette compartment) or a cotton swab with a soft solvent (e.g. rubbing alcohol), carefully clean the transporter roller and print head. Dust, dirt, or glue may accumulate on the rubber transport roller or print head inside the cassette compartment and adversely affect print quality.
If the solutions listed above do not resolve the problem, please contact DYMO Technical Support to obtain a Return Material Authorization (RMA) Number.
Obtaining a Return Material Authorization (RMA) Number:
  1. Click the Ask a Question tab at the top of this FAQ.
  2. Fill out the email form completely and include the following information in the Problem Description field:
  • Full Name
  • Full Shipping Address (No PO boxes)
  • Phone Number
  • Date of Purchase
  • Model Name/Number
-hope this helps.
Posted on May 19, 2008
MCSE_Fixit
  • 23 Answers
SOURCE: how do you print vertical labels?
Here is the link to your users manual, which will help explain other functions you may find useful.
http://global.dymo.com/enGB/Manuals/LetraTAG_QX50.html
Hope this helps...
Gods Bless.......
Posted on Jun 22, 2009
SOURCE: Does a DYMO Letratag QX50 have a replaceable ink
It is a thermal printer and thus does not use ink.
The most likely cause of poor print quality is low batteries. Replace your batteries or plug in the power adapter.
If this does not help check that the label cassette is in place correctly and that the print head is clean. You could also try a new label cassette.
Posted on Jan 31, 2010
  • 43 Answers
SOURCE: dymo letratag 2000
Dymo don't do spare parts for their machines - because most of them are so cheap now that it's much cheaper to buy a new one than it is to repair them.
This is especially so for the LetraTAG machines which are the cheapest in the Dymo label maker range.
For that price it's a no-brainer - if the display is unreadable just buy a new one!
Posted on May 23, 2010
Why do the first to letters and the last letter print funny on my dymo letratag
Not clear what "funny" means in this case. Are the letters unclear? distorted? It may be that the batteries are failing.
^CM
DYMOsupport
Jun 10, 2014 | Dymo LetraTAG Thermal Label Printer
Dymo Letratag Flashing Screen
kindly see the correct voltage rating of your battery.
Aug 29, 2012 | Dymo LetraTAG Thermal Label Printer
Dymo Letratag LCD screen not working
not easy to fix its dirty contacts on the lcd
can be cleaned an reassembled but not worth it unless your techy nerd like me.
Mar 08, 2012 | Dymo LetraTAG Thermal Label Printer
Dymo letratag 2000
Apr 26, 2010 | Dymo LetraTAG Thermal Label Printer
Labels coming out blank
1. Replace the batteries (use only alcalines)
2. See if the tape is correctly inserted.
3. Clean the printer head
4. Replace the tape with a new one.
5. Check the contrast settings
Jul 20, 2009 | Dymo LetraTAG Thermal Label Printer
Dymo LetraTAG Problem with the screen.
most likely it's a firmware update. or the led could be toast(happens after a period of time)
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Dymo LetraTAG Thermal Label Printer
Dymo letratag, instructions
I found a download for the instructions. Go to Dymo webpage. Igot there from google.
Click support, FAQ, fill in letra lable makers, and instructions.
Go a few pages in they are there. Good luck.
Feb 04, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Dymo LetraTAG Thermal Label Printer Logo
163 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
