Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
I turned ON my LP gas detector in my Fleetwood '97 RV and left it turned ON. Three days later I noticed that my detector light was out. I toggled the ON/OFF switch and got nothing. I checked the fuse box in the engine compartment and discovered that both 5Amp fuses connected to the LP detector had blown. Any advice?
  • 6,674 Answers
First I'd remove screws and pull detector out to see if perhaps any loose wires that may have touched each other or a ground. Second, check for any bad connections as well at solenoid on propane line feeding system. Being how it says it's a Motorhome, the propane detector usually has to be on to activate solenoid to open gas flow to appliances etc. If all connections appear good, you may have a bared (+) wire (short) that you need to look for. Area around wires coming from propane solenoid is a good place to start, seeing how they are usually exposed to the elements, more than interior wiring. You may end up having to disconnect one or the other or both to start with, and then re-attach one at a time to determine which way to go, As in a wire running to fuse box, or wire running from solenoid below at propane tank. Can't rule out shorted solenoid as well.
Posted on Oct 04, 2010
Where to find the fuse block location in our RV92 Fleetwood Bounder
it is accessible from the top of the dash. The left panel is secured with velcro and should just pull up.
__________________
Apr 03, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
We cannot get any lp to any appliances
Obviously the detector must be faulty, or bad connection from detector to gas valve on system. You'll have a power wire coming in to back of detector that you need to attach directly to wire going to gas valve in line near connection at tank. Use a continuity tester/multimeter to determine which wire. Check all connections at back of propane detector and make sure power to it, before resorting to direct connection temporarily until detector can be replaced. Should have power in only on one wire when off, and power at other wire(s) except ground when turned on. That wire will be (should be) the one going to gas valve near tank.
Sep 05, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
We had been in our RV for many hours running the air conditioner and then we strated to smell something for about an hour and then LP Arlarm strart going off. It did not smell of LP. When we got out side...
Yes, those detectors will trip on many gases, and if your battery or Batteries are boiling that bad, you should have them and charging circuit (converter etc.) checked.
Jul 25, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
How to connect 4, 6 volt batteries on a 2005 fleetwood expedition
Assuming that you want a 12 volt equivalent, you should wire the batteries as in the following diagram.
If you are looking for some other configuration, post a reply.
Dec 27, 2010 | Rv Motorhome Dual Co & Lp Gas Alarm...
2006 Sandpiper travel trailer - The LP gas detector keeps going off and we didn't even have the gas turned on.
May be faulty and need to be replaced but check for proper voltage to it first. Some of those detectors can go off from hairspray, deodorant spray, perfume, high humidity, etc (aerosols)
Even a dog laying close to it with a little gas can do it sometimes. (lol) seriously. Do you have a battery hooked up to your trailer as well, may help.
Jun 01, 2010 | Rv Motorhome Dual Co & Lp Gas Alarm...
MH LP tank gauge says 3/4 but suspect it is empty. How do I verify gauge inop?
Poured boiling water over lp tank and then felt the tank. It was noticeably cold at the LP line.
Dec 13, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Recently purchased and did not come with owners manual and want to learn the trailers accomidations
You can order a Fleetwood Owner's Manual by sending a check or money order for $8.00 to the address listed below. If you require a chassis manual, you can contact the chassis manufacturer directly.
Fleetwood Service & Training Center
PO BOX 1007
Decatur, IN 46733
May 25, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
I need a service manual for Atwood 2001 series RV LP gas detect
Call one of the motor home supplier and you will be able to get it.
Mar 30, 2009 | RTO Atwood Water Heater - 6 Gal LP
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
641 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Mike
Ken Strite
Ken Strite
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
