Question about Frigidaire ATF6000ES Front Load Washer
Door Leak My 4 year old Frigidaire front load Washer is leaking via the door is there an adjustment?
  • Anonymous Mar 20, 2014
    3 year old front load stacked inglis washer is leaking bad, can the seal be replaced by a diy person
  • 868 Answers
Not usually ,replace the gasket if you cant re set the old one.
Posted on Jun 03, 2008
How do i get the door open on a frigidaire front load washer?
check underneath the washer below where the handle is for a ring. pull to manually release lock.
Dec 02, 2014 | Frigidaire Washing Machines
I see water down on the floor after the wash load is completed. Initially when washer starts, there is water on the ground.
Your observation of the leak is very important to confirm the point of leak. Check for leak from the door gasket on the front door, check for drain pump/valve leak, check for drain hose leak from a faulty clip.
Jan 22, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Gallaxy Series top loading washing machine, 4 years old that seems to be leaking from the bottom. Is this something I can fix myself? THANK YOU.
Before you buy a new $100 door gasket, pull out the soap dispenser tray and look inside the washer where it normally sits. If there is significant soap accumulation (even 3/8 inch), the water can become backed up and trickle down the washer front to the door bottom, making it look like a door leak. Fixed mine this way.
Jul 30, 2010 | Washing Machines
I have an 11.5 year old Frigidaire Gallery with an increasing leak present at the end of each load. A drip pan has been enough to catch it so far, but am concerned I'm seeing more and more water. Expected...
could have a leaking drain hose, pump. If your handy and dont want to spend several hundred dollars for a new washer and the washer is working fine veside the leak, I would just fix the leak.
Aug 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Water Leak
when you clamped it down you will have to add a 1/2 inch pipe ,about 5 inches is long enough.Use the pipe to clamp your hose to with adjustable clamps not Spring clamps.The pipe serves as a union here. Please rate this !
Jun 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Water leaking out the bottom of the door
You most likely need to make a small adjustment to the door. While the door is open push the bottom of the door towards the machine and pull the top of the door away from the machine, be careful not to go too far. that should take care of the leak. Before you do that make sure the water is coming out between the glass and the seal. I would remove the lower panel and make sure the seal doesn't have a small hole. You should see the seal leak from the inside. Hope this helps
Jan 13, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
458 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
